I need a manual tranny
Old Jun 15, 2006 | 09:02 PM
slowup's Avatar
slowup
Originally Posted by JustinD
I live in Minnesota and I'm 17. So it would be hard to get down there to try it. What is the horsepower rating on it? What would I need to stick it were my th350 is?
Dang ur 17? i thot i was the youngest guy here and im 18.
Old Jun 15, 2006 | 10:17 PM
JustinD's Avatar
JustinD
Yup, gonna be 18 in october. you got a vette?
Old Jun 15, 2006 | 10:24 PM
lucky76's Avatar
lucky76
Originally Posted by lowbuck72
I don't need any of that stuff. I am planning on converting my '68 Chevy van from a Saginaw 3 speed to a 4 speed (on the tree).A wide ratio M20 will do the trick.
How does a 4 speed on the tree work?
Old Jun 15, 2006 | 11:22 PM
slowup's Avatar
slowup
of course i gotta vette. I just dont have n e pics of it on my comp...but its a 74' and urs looks pretty good to!
Old Jun 15, 2006 | 11:43 PM
birdsmith's Avatar
birdsmith
JustinD, I just finished a TH400-to-Muncie M20 swap on my '70 in April. I tried to do it as cheaply as possible AND as quickly as possible; which is to say because of time considerations I had to pay more for some items than I otherwise might have. If you can live with a muncie 4-speed that would be the simplest swap as you can use parts that were originally designed for your vette and you wouldn't really be 'modifying' anything. I you just gotta have extra gears, the Keistler kit is really the Cadillac of those for close to $4000. After I was finished with mine I had spent $1800, but I had to pull the trans back out and throw a rebuild kit at it ($230) and then two days after that the ebay junk Z Bar broke-$90 to replace that. If you'd like, I have a complete itemized list of every last nut and bolt used in the swap, where it all came from, and what it cost. PS I might be interested in your TH350 slip yoke and I have a very nice TH400 yoke......
Old Jun 15, 2006 | 11:51 PM
JustinD's Avatar
JustinD
I would be interested in the parts list. If you could email it to me that'd be swell. jud3612@comcast.net
Old Jun 16, 2006 | 10:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Nice car!
Old Jun 16, 2006 | 11:13 AM
JustinD's Avatar
JustinD
Old Jun 16, 2006 | 06:57 PM
Little Mouse's Avatar
Little Mouse
I had the M21 behind my 454 it stood up to it. it had a lot more torque
and HP the 425 I did not drag race it. Find a good trans from late
70s vette or camaro.
Old Jun 17, 2006 | 12:18 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Mine is a M21 Super T-10 out of a 78 Vette with 7000 miles on rebuild. Works perfect.
Old Jun 17, 2006 | 12:57 AM
JustinD's Avatar
JustinD
I'm worried about the install.
Old Jun 17, 2006 | 03:03 AM
Little Mouse
Default bellhousing
Justind I have two aluminum bellhousings you can have they are just
collecting dust around here I will never use them
Old Jun 22, 2006 | 01:24 PM
  #33
JustinD's Avatar
JustinD
So, to do a swap what do I need. Does anyone have like a complete list maybe?
Old Jun 22, 2006 | 01:37 PM
  #34
Little Mouse
I will give it a go you will need, trans, shifter, bellhousing,clutch fork,
flywheel, clutch, Z- bar, ball stud for Z-bar. clutch rod for clutch fork,
different clutch and brake pedals. this is a good start
Old Jun 22, 2006 | 01:50 PM
  #35
JustinD's Avatar
JustinD
that should be good to start with. How much will I be able to get for my TH350? It is smooth and shifts nice.
Old Jun 22, 2006 | 02:01 PM
  #36
Little Mouse
almost nobody wants a turbo 350
Old Jun 22, 2006 | 02:08 PM
  #37
JustinD's Avatar
JustinD
Sweet, even better.
Old Jun 22, 2006 | 02:43 PM
  #38
davidm_comp's Avatar
davidm_comp
Might as well go with the overdrive right off the bat....Get a T5 out of a Mustang or Camaro. I have one sitting on the bench waiting until winter to through into the car.
Old Jun 22, 2006 | 04:43 PM
  #39
spookytooth's Avatar
spookytooth
justind, i would recommend that you work with the stuff you have.
to put a manual trans. in your car is not that difficult if you have the right tools, equipment and space to work. You have to work out the problems with floor mods., welding in a bracket for the clutch pivot, possible x-member mods. The real problem will be trying to dial in the new bell housing with the engine in the car (unless you want to pull it).
A great project for a young guy if you had a project mentor there to help you. On your own and getting help from this site it may be too difficult for members to accurately convey useful tips.
just a suggestion.
