Ported/Manifold Vacuum
Old Jun 21, 2006 | 02:34 PM
JustinD's Avatar
JustinD
Default Ported/Manifold Vacuum
Which do you guys prefer and why.
Old Jun 21, 2006 | 02:37 PM
ImBatman's Avatar
ImBatman
Good question. I was going to ask which to use for Vac advance.
Old Jun 21, 2006 | 02:39 PM
JustinD's Avatar
JustinD
Thats is what I'm using it for also.
Old Jun 21, 2006 | 02:41 PM
jotto's Avatar
jotto
There seems to be two schools of thought for this one but from what I have read and advice received from recent posts regarding timing...manifold vacuum seems the way to go.
Old Jun 21, 2006 | 03:00 PM
sperkins's Avatar
sperkins
I prefer to run ported vacuum. Last week for example I tried manifold vacuum (low HP smog motor) and here's what I got.
Ported vacuum yeilded 12*BTDC at idle with vacuum capped (with new distributor). Advance connected @ 2500 gave me about 30* if I remember right.
Manifold vacuum gave me 35* at idle.
Maybe it's just me, but I like to keep things as original as possible. Plus, it runs great with ported vac so why change it?
Old Jun 21, 2006 | 03:08 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
With the cam I have in the big block I needed to use manifold vacuum to the distributor to provide the extra advance at idle to compensate for the residual EGR caused by the cam overlap. A noticeable improvement in idle quality resulted from that.
Old Jun 21, 2006 | 03:30 PM
JustinD's Avatar
JustinD
I just switched to manifold for ported and it runs better. I get my full 36* buy 2500 now. Maybe is is my cam that was making ported not work as well. Advertized Duration: 290 in and 297 ex
Old Jun 21, 2006 | 03:42 PM
jeckel's Avatar
jeckel
justind, imo your are correct, with the cam you are running you probally should be using the manifold for the vac advance to help compensate a bit. Just my oppinion.
Old Jun 21, 2006 | 06:35 PM
694speed350's Avatar
694speed350
Manifold is best for performance. ported is for emissions. my engine is stock but it runs better on manifold.
Old Jun 21, 2006 | 07:09 PM
Gordonm's Avatar
Gordonm
Vacuum advance should have no bearing on your full advance when you are in it. The vacuum drops out when you are on it. You should be getting a full 36 degrees with the vacuum disconnected. You want an additional 14 to 16 degrees of vacuum at cruise rpm for a total of about 50 to 52 with vacuum.
At idle I run ported and it gives me about 26 degrees of advance. With the big cam duration 252/260 @ .050 it likes the advance at idle and runs cleaner and smoother.
Old Jun 21, 2006 | 09:24 PM
BarryK's Avatar
BarryK
this is 100% correct
vacuum advance was always run on full manifold vacuum until the emission requirements to lower hrdrocarbons affects how they had to run the motors.
To lower hydrocarbons they needed a retarded spark at idle, hence the ported vacuum which gives no vacuum advance at idle but than works the same as a full manifold vacuum once the throttle blades are cracked open.
Ported vacuum is good for emissions but bad for performance
Typically a full manifold vacuum source will give you a smoother idle characteristic, better throttle response, better fuel milage, and lower operating temps.
Old Jun 21, 2006 | 11:44 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
BarryK is spot on. Also, if you're running a big cam and low vacuum at idle, you'll need another vacuum can than the stocker. The stockers' cans are usually all in at 14-15hg of vacuum. If your cam idles below that, the idle will always be inconsistent. So if you have a 12 inches of vacuum at idle, run a can that's all in at 8 inches. The Echlin VC-1810 fits the bill. Seems I reads somewhere here a spreadsheet with all the cans, vacuum characteristics, and part numbers. Perhaps somebody knows where it is.
Old Jun 22, 2006 | 12:14 AM
JustinD's Avatar
JustinD
Well, mine seems fine. But I do get a backfire at low rpm's when I jab it quick. Could this be the problem? All other things seem to be fine.
Old Jun 22, 2006 | 08:52 AM
The Money Pit's Avatar
The Money Pit
The inconsistant idle is exactly why I run ported. I would come to a stop after cruising and the idle would take 30 seconds to come back down.I just found out (new vacuum guage) that my at idle vacuum is 5" or so,and I guess the distributer was taking it's time stabalizing the timing at idle. With the ported source,as soon as I'm off the throttle,the vacuum goes to zero,and the vacuum advance drops like a rock.Idle is now not a problem.It is true the added advance will smooth things out at idle,but I rather enjoy hot coffee in my lap with my rumpy idle..........
Old Jun 22, 2006 | 09:30 AM
...Roger...'s Avatar
...Roger...
You could benefit from a can that has a weeker spring and is all in at 5 or one thats adjustable to almost any vacumn.Your missing the benefits of "manifold" vacumn.Crane has them.
Old Jun 22, 2006 | 10:52 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
The Search function is your friend. Do an archives search in both C3 and the C1-C2 forums for a wealth of info on which vacuum cans to consider if you are changing from ported to manifold. Lars and SWCDuke have some great posts on this.
Old Jun 22, 2006 | 12:41 PM
BarryK's Avatar
BarryK
the paper is by Lars and know exactly where it is...........
I have it hosted up on my website on my tech articles page here:
http://69.253.166.197/page1/page65/page65.html
The article's file name is called Vac Adv Specs.pdf
To Ported/Manifold Vacuum
Old Jun 22, 2006 | 12:57 PM
JustinD's Avatar
JustinD
I'll look through that and see what the next step for me is.
Old Jun 22, 2006 | 01:38 PM
BarryK's Avatar
BarryK
Backfiring up thru the carb usually indicated a too rich mixture. Popping out thru the exhaust indicates a too lean mixture
Old Jun 22, 2006 | 01:44 PM
JustinD's Avatar
JustinD
Should I jet down to 70's maybe? Lean out the idle mixture some also?
