Cleaning metal
Here are some links describing what electrolysis is:
http://www.stovebolt.com/techtips/ru..._derusting.htm
http://antique-engines.com/electrol.asp
All I needed was a plastic garbage can, some old sheet metal, a battery charger and some soap. Unfortunately, it doesn't seem to take paint off like sandblasting can, but it's amazing how well it works on rust (and even grease to some extent).
Before:
Making rust soup:
After...all rust moved from control arms to donor metal, no elbow grease required. The black color is iron, which is rinsed and powder coated/painted right over:
powder coated and on the car:
I did this for the drive shaft, half shafts, steering knuckles...even my original jack. I wanted to do my frame this way, but I didn't have a spare swimming pool lying around...
Would something more agressive like muriatic acid be safe for the knuckle parts and seat tracks?
Here are some links describing what electrolysis is:........
Brake parts cleaner works great and will remove some paint...it leaves the surface without any detergents or oil so you can paint. My engine builder had me spray down my block once it was prepped to paint, to ensure no grease and to leave a clean surface.
