What are your next planned mods?
Old Jun 15, 2006 | 05:37 PM
panic's Avatar
panic
Originally Posted by 69427
I've always been curious when someone (a lot more talented than me!) would attempt something like this just to have something unique.
Next item: aluminum block
sixtynine..i think there is a co. that already builds these pieces of art, i saw somewhere a pic...but i forgot the web address
Old Jun 15, 2006 | 06:48 PM
theandies's Avatar
theandies
Replace my "Rag" top. Priorty 1.
Install 2.5 or 3 inch exhaust with an X pipe and some better mufflers.
Some interior parts.
Light weight battery (if your real world tests work out).
I might get GM's ZZ4 hot cam to bump up the HP's a little.
It's a work in progress and my ideas change everyday.
Old Jun 15, 2006 | 07:29 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by MotorHead
427-434 ci small block, 18 degree heads, 7,500 RPM screamer, tired of this off the shelf stuff
Originally Posted by panic
who builds these sweet animals?
A guy named MotorHead, he goes into his basement in the fall and next spring out it comes ( on fridge cart to get it up stairs )
Old Jun 15, 2006 | 07:48 PM
doug_dayson's Avatar
doug_dayson
For my 71 Coupe 406/375_700R4_Steeroids R&P:
1) VB&P Upper A-Arms in front to get more Caster for the Steeroid's R&P.
2) Tires for the late C3 Alloys (15 X 8).
3) Either EFI or Tremec 5 conversion from the current 700R4.
4) Either EFI or Tremec 5 conversion from the current 700R4.
For the stock 91 Z07 Coupe:
1) Fix the HVAC Temp Door (no fun).
Doug
Originally Posted by fl_rider
1. Rebuild rear suspension (Strut Rods, Trailing Arms and left rear wheel bearing) I just did the right rear.
2. TPI
3. Paint
4. Interior
Oh yeah.... Fix the AC and Heater
I know there will be more.
Old Jun 15, 2006 | 08:32 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Crazy sheet
Old Jun 15, 2006 | 08:38 PM
BerniesVette's Avatar
BerniesVette
Hydroboost, Jeep Steering Box, Aluminum heads, Aluminum Intake, New Carb, Headers, Wheels & tires, and next Mad Electric complete Upgrade.
Bernie
Old Jun 15, 2006 | 08:48 PM
jpatrick636's Avatar
jpatrick636
Six link rear suspension.
New trailing arms.
Dual MSD ignition.
New fuel system.
Old Jun 15, 2006 | 08:52 PM
bozzman3's Avatar
bozzman3
Nitrous
Old Jun 15, 2006 | 08:56 PM
slowup's Avatar
slowup
Default ummmm
i got to much to list,
Old Jun 15, 2006 | 11:56 PM
682XLR8's Avatar
682XLR8
....to get my last set of mods working! Hopefully, if everything goes right, I'll get my new 383 running Saturday
Old Jun 15, 2006 | 11:58 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Start building a blowthrough carbuerator for turbocharging.
Probably something akin to a Holley 600 or 650 cfm double pumper
Old Jun 16, 2006 | 12:01 AM
Corz's Avatar
Corz
a 4 sale sign
Old Jun 16, 2006 | 12:14 AM
  #33
Beater's Avatar
Beater
I'm working on wiring up an all LED center brake light.
LED tail lights taken from Semi trailer units and adding stock covers will follow shortly there after.
Roller Rockers
Cam
This of course is in addition to the continual restoration/upkeep.
Old Jun 16, 2006 | 01:38 AM
  #34
panic's Avatar
panic
Old Jun 16, 2006 | 02:34 PM
  #35
1bumprfan's Avatar
1bumprfan
just ordered headmen headers 68-300 for 73 SB350. plan on tackling that in July. $200 CDN brand new from performance unlimited in London, ON (thanks beaky!)
undertaking a major shim job to get rid of some some spongy brakes this weekend, but that's not really a mod..,
Old Jun 16, 2006 | 02:40 PM
  #36
vettlibito's Avatar
vettlibito
Stereo, and I'm going to throw a 1 or 2in spacer on the carb... Just for the hell of it..
Old Jun 16, 2006 | 03:39 PM
  #37
iree75's Avatar
iree75
Well once I get the thing together after doing.. rebuilt all suspension, new springs - shocks, new calipers, rotors, all brake lines, replaced body mounts, gutted interior - installed dynamat extreme, replaced - rebuilt all steering components, all wiring harnesses, replaced heater core, all A/C components, vacuum hoses, .... to the engine bay... BB 427, .040 over, March serpentine belt conversion, Centerforce dual friction clutch, DeWitts radiator and fan kit with multi speed controller.
Still need to get-
Aluminum covers for 68 look side exaust.
Hydroboost.
... future
New paint
AFR 305 heads
wilwood calipers
another job to pay for this stuff... and earplugs so I don't have to hear the "now how much is it worth now?" questions..
-F
To What are your next planned mods?
Old Jun 16, 2006 | 03:49 PM
  #38
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Carb Rebuild and Tune (In progress)
New Exhaust system w/ Flowmaster 40 Delta Flows
(parts are in hand...next after carb)
Wheels and Tires (Torque Thrust D + BF Goodrich VR-TA)
Any Suspension mod required for a glassy smooth ride
Old Jun 16, 2006 | 10:38 PM
  #39
SIXFOOTER's Avatar
SIXFOOTER
'81 coupe Restomod:
Urethane bushngs all around
VBP O-ring caliper kits
SS Brake lines
New left front fender
New front bumper
new windshield
Paint
sound proofing/ heat barrier
Engine top end kit (options still open)
200R4 transmission
3:73 gears
Ummm....
floor mats....
Old Jun 17, 2006 | 09:49 AM
  #40
LFZ's Avatar
LFZ
switching over to synethetic Mobil 1.
