WEDGE spacer?
Old Jun 16, 2006 | 03:18 PM
CGGorman's Avatar
CGGorman
Default WEDGE spacer?
My carb sits at a bad angle to jive with my L88 hood. It works, but it's borderline. I've seen 5* and 8* wedge spacers, but I'm hesitant.
See how the gasket around my filter base is unevenly smashed? That's from the "bad" angle.
What's the word? Anybody ever use a wedge spacer?
Old Jun 16, 2006 | 03:37 PM
pef427's Avatar
pef427
I too will face this same prob...any advice is appreciated.
Old Jun 16, 2006 | 11:07 PM
pef427's Avatar
pef427
Ttt
Old Jun 17, 2006 | 06:00 AM
Fevre's Avatar
Fevre
Do not care for the looks of that wedge, seems it would cause the nuts to not contact the carb base flush unless the washers they provide are also angled
Old Jun 17, 2006 | 07:41 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Jughead's Avatar
Jughead
St. Jude Donor '09
Good point.
Old Jun 17, 2006 | 07:42 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Old Jun 17, 2006 | 08:18 AM
SIXFOOTER's Avatar
SIXFOOTER
dammitman! LOL. yes it would make the mount nuts contact the plate at an angle, not sure if thats a real problem or not, I would use SS washers under the nuts and NYLOC nuts or something like them to mount with I think.
Old Jun 17, 2006 | 08:41 AM
Chandler's Avatar
Chandler
Hi, if you use the wedge spacer, you can buy a leveling shim, and use it like a washer under the nut. or make your own.
http://www.mcmaster.com/
90845A015
18-8 Stainless Steel Leveling Shim 5/16" Screw Size, 11/32" Hole Dia, 7/8" Square Size
In stock at $8.41 per Pack
This product is sold in Packs of 5
these seem big, but the idea seems right.
Old Jun 17, 2006 | 10:12 AM
PRNDL's Avatar
PRNDL
Originally Posted by Jughead
Good point.
sure, but is it a good point X 8 ????
Old Jun 18, 2006 | 09:19 PM
scotty13's Avatar
scotty13
wouldnt it mess with the level of fuel in the bowls?......
Old Jun 19, 2006 | 12:56 AM
Little Mouse's Avatar
Little Mouse
Default wedge spacers not for stock cars
The reason intakes are higher on the back is to compensate for the
angle of the engine so the carb will stay level and the fuel floats
will work right. wedge spacers are for racers that have changed the
angle of there motor to help them get there carb back to level.
A level carb is important. mod the base above your carb if you
do not like the fit to the hood.
To WEDGE spacer?
