427 Starter woes, HELP
Old Jun 16, 2006 | 09:20 PM
rickales's Avatar
rickales
Default 427 Starter woes, HELP
A little late but it is time to break out the old 68 after parking her last fall. Charged the battery, cover off, check fluids, polish, check lights, eveything looks fine. Hit the key and NO VRRROOOOMMMMmmmmm!
I hear a very muffled "click" from the cockpit but nothing else. With the key in the START positon, the lights don't dim, no solenoid noise, no click click click... just one muffled "click" when I got to START and one muffled "click" when I relaease.
Eveything was fine when I parked her last fall, Any thoughts?
Old Jun 16, 2006 | 09:42 PM
PRNDL's Avatar
PRNDL
Originally Posted by rickales
Any thoughts?
I know you want to think it's the starter.
I know you charged the battery.
This has happened to me about 3 times, and every time it was simply the battery!
Old Jun 16, 2006 | 09:56 PM
griffths's Avatar
griffths
Automatic or manual? If the battery is fully charged and the lights don't dim when you attempt to start the engine I would suspect the neutral safety circuit. It was bad on my car and would work intermittently and turned out to be corrosion in the bulkhead connector that was preventing the circuit for engaging the starter.
Jay
To 427 Starter woes, HELP
