Mighty Demon Owners...
Old Jun 16, 2006 | 10:56 PM
enkeivette's Avatar
enkeivette
Default Mighty Demon Owners...
What kind of throttle cable brackets are you using? My single bolt spectre bracket keeps moving.
Old Jun 16, 2006 | 11:15 PM
Jack71's Avatar
Jack71
I had a helluva time with this on my Speed Demon. I ended up switching to a Lokar cable and going with a two bolt bracket.
Swapping the cable was not as bad as I expected.
Old Jun 17, 2006 | 02:15 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I using one of the milled aluminum type that attaches to both of the driver side bolts and has an adjustable cable hold down along with a Locar cable. Can't remember the exact company, but alot of places make ones like it (Jegs, Holley, ....). Usually runs ~$50.
Old Jun 17, 2006 | 04:24 PM
C3 Stroker's Avatar
C3 Stroker
I now use a Lokar....before that, I added a small metal spacer tab on the stock bracket to prevent it from moving.
Old Jun 18, 2006 | 11:19 AM
surveyor3447's Avatar
surveyor3447
Default demon bracket
the bracket from CSR works great. I had the same problem but this has fixed it for good.
Old Jun 18, 2006 | 06:56 PM
SmokedTires's Avatar
SmokedTires
St. Jude Donor '05
That's the same senerio as me Lokar has been working great so far
Old Jun 18, 2006 | 07:22 PM
Gordonm's Avatar
Gordonm
Lokar here also.
Old Jun 22, 2006 | 04:01 PM
enkeivette's Avatar
enkeivette
Can you see the bolt? Just drilled the Spectre bracket a little bit and used a bolt that I had lying around. Solid as a rock.
To Mighty Demon Owners...
