adjusted my lifters and everything else
Old Jun 17, 2006 | 04:39 PM
1Z87L8's Avatar
1Z87L8
Default adjusted my lifters and everything else
Tell me if i did this right, by right i mean proper sequence.
#1 Adjusted my lifters the Lars way.
#2 brought engine to operating temperature
#3 set the timing (8 deg Before for now, Lars method will be done after new dist is installed)
#4 set Carb with vacuum gauge, adjusted until i hit highest peak which ended up at 20"
#5 set idle speed to 700rpm.
sounds good to me, throttle is responsive now and the best part is
NO MORE LIFTER TAP!!
Old Jun 17, 2006 | 04:42 PM
Bob Onit's Avatar
Bob Onit
Sounds like tou did it right to me!
