Tachometer filter test question
Old Jun 17, 2006 | 04:43 PM
1Z87L8's Avatar
1Z87L8
Default Tachometer filter test question
while working on the car today i plugged the filter back in and hooked
my tach/dwell meter to it and got nothing, i then pulled the filter from the distributor and hooked the tach/dwell meter directly to the distributor and it worked.
am i correct in assuming that the filter is shot?
Old Jun 17, 2006 | 04:51 PM
Greg's Avatar
Greg
Just another Corvette guy
Probably right from what you describe.
Old Jun 17, 2006 | 11:24 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Sound's like it could be. I'll toss in a breadboard version of a tach filter you can use when I return the tach board. As long as you don't need "stock looking", this will work fine.
Old Jun 18, 2006 | 11:24 AM
1Z87L8's Avatar
1Z87L8
George,
hit you with a e-mail regarding the filter.
thanks again for all your help
To Tachometer filter test question
