HELP!! Mystery Wire!?!
Old Jun 17, 2006 | 09:28 PM
Adam Wartell's Avatar
Adam Wartell
Default HELP!! Mystery Wire!?!
What is this wire? What is the silver thing it is coming out of and where is the flat connector end supposed to go?
This picture was taken on the left wall of the drivers foot area (to the left of the fuse panel.). This is a 1979.
http://www.c3vr.com/member_uploads/1...sterything.jpg
Help!
Thanks!
Old Jun 17, 2006 | 10:08 PM
David Ey's Avatar
David Ey
Take it off and chunk it. It looks like a condensor or noise suppressor.
Old Jun 17, 2006 | 11:10 PM
blu69sting's Avatar
blu69sting
6th Gear
Default wire
hmm so maybe something to do with the door ajar stuff?
Old Jun 17, 2006 | 11:32 PM
Greg's Avatar
Greg
Just another Corvette guy
YUP!
Old Jun 17, 2006 | 11:48 PM
Adam Wartell
I do have an aftermarket radio in there. I'm wondering if I pulled the flat end out of something when I was pulling fuses. How would I know if I need to plug it back in? And if I do need to plug it back in, how do I know where to plug it?
Thanks for the help!
Old Jun 18, 2006 | 06:20 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
It's probably either the main power feed or the memory "keep alive" line to the aftermarket radio as that sure looks like a noise suppressor cap. I'm assuming there is 12V a the connector. If it's switched (off w/key out) then it probably the main feed. If it's hot all the time, it's probably the memory line.
Good Luck!
Old Jun 18, 2006 | 06:57 PM
RHD '68 L89's Avatar
RHD '68 L89
The silver thing is a Condensor, Capacitor or noise suppressor. It goes by all of these names. the wire is not "hot" with 12V (unless you connect it to the power!). The case of the Cap is grounded to the birdcage. It is used to stop/reduce electrical noise getting into the audio system. It is usually connected to the power line going to the radio to filter out the noise on the power supply line.
It is not necessary unless you are getting noise such as alternator whine in the audio system.
To HELP!! Mystery Wire!?!
