carb question
Old Jun 19, 2006 | 03:03 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default carb question
[theoretical]
If I am going to build a carb with a 4-corner idle setup, and I buy the holley HP main body, do I use another primary metering block with a power valve plug?
I am looking to make a 650 double pumper with an HP main body and a 4 corner idle, for my blow through turbo project.
I might just slowly peice all the parts together and build an all new carb, that might be fun. I am just having a devil of a time finding a good secondary with an idle circuit.
Old Jun 19, 2006 | 11:33 AM
Brettmc's Avatar
Brettmc
Primary and secondary blocks can be interchanged on 4-corner carbs. BLP and AED have some mighty fine blocks if you are building a carb from scratch. Those ***** have adjustable PVCRs and adjustable idle feed restrictors for the ultimate in tuneability.
Old Jun 19, 2006 | 04:29 PM
Guru_4_hire
Cruise-In V Veteran
That sounds pretty dang nice
I guess if I am going to blow 99 dollars on a metering block I might as well go all the way right?
AED also offers a wonderful baseplate WITHOUT vacuum ports, that will also come in handy
To carb question
