Drive shaft question...
Old Jun 19, 2006 | 10:38 AM
sly vette's Avatar
sly vette
Default Drive shaft question...
After installing my eng and trans(4 speed), I find that I have the engine in at the proper offset. What I am concerned about is that the driveshaft is absolutly level. Is this something I should be worried about or is it O.K.?
Later,
Sly
Old Jun 19, 2006 | 11:40 AM
sly vette's Avatar
sly vette
Test...
Old Jun 19, 2006 | 12:53 PM
kevinator80's Avatar
kevinator80
You need a little angle in the driveline, but the offset you mention should take care of that. When I swapped to the 700 I set my tailshaft a little low so I could shim up if needed.
Old Jun 19, 2006 | 12:56 PM
sly vette's Avatar
sly vette
So you feel that the side angel of the drive shaft is enough to have it perform properly???
Old Jun 19, 2006 | 03:34 PM
BKbroiler's Avatar
BKbroiler
Whether you have a slight angle or none at all, doesn't matter. Thats what your universal joints are for.
Old Jun 19, 2006 | 03:40 PM
Twin_Turbo's Avatar
Twin_Turbo
it does matter, you need some angle to keep the universals moving so they don't freeze up. The engine/trans is designed to be offset from center (the pinion is offset also but not as much) and angled about 4deg down, the pinion is angle 4 deg up. Equal yet opposite angles is what you want.
Old Jun 19, 2006 | 10:27 PM
sly vette's Avatar
sly vette
Is the side to side offset enough to make the verticle offset work .i can see about a 3 * vertricler offset from the trans to the pig.
To Drive shaft question...
