THM350 Shift Shaft Seal Replacement
Old Jun 20, 2006 | 10:47 AM
tommyleea's Avatar
tommyleea
Default THM350 Shift Shaft Seal Replacement
Anyone with experience on this topic. My shift shaft seal is leaking, and I plan on replacing it. I think there is a special tool for this, but am wondering if anyone knows of an alternative method without the special tool. Thanks..
Old Jun 20, 2006 | 12:29 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No special tool really needed. There is the right way...and the easy way.
The right way is to drop the pan, unbolt the linkage inside and outside. slide shaft out and then use a screwdriver and pry out old seal. Then you can install the new one with a small socket to drive it in. Then reassemble everything.
The easier way that MIGHT work, is to remove linkage on outside of trans only and dig out the old seal with a small icepick or something. Then drive a new seal in.
You can also usually just drive the old seal in deeper and install another seal on the outside of it. The bore is usually deep enough.
With either method, a bullet proof way is to install two seals in there regardless.
Make sure shaft isn't scored up any. If it is,. make sure the new seal rides in a new place on it.
JIM
Old Jun 20, 2006 | 02:32 PM
kevinator80's Avatar
kevinator80
After digging at one of these for atleast an hour and risk scoring the sealing surfaces, I think I would try 427Hotrod's idea the next time I have to do one.
Old Jun 20, 2006 | 08:12 PM
knbwag73's Avatar
knbwag73
I have the same issue on a 73 TH400. Will the same process work,just push the existing seal in and add a new one on top of it?
Where can I get a replavement seal?
Old Jun 20, 2006 | 09:28 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
JIM
I did it "the right way." No special tools needed and no leaks either. What you have to be VERY careful about is making sure that you put all the linkages together properly. Otherwise, you won't be able to shift into any gear and have to take it appart again.
Ask me how I know.
Old Jun 20, 2006 | 09:29 PM
CA-Legal-Vette
Any car parts store. I got mine in a gasket set but I'm pretty sure that you can get it separately as well.
Old Jun 20, 2006 | 10:02 PM
427Hotrod's Avatar
427Hotrod
T-400 is the same way. It's not that hard to drop the pan and do it the "official" way...probably need to change filter and install a shift kit anyway right?
Either way, two seals is a good idea.
JIM
Old Jun 23, 2006 | 07:41 AM
tommyleea's Avatar
tommyleea
A friend of mine had the special tool to change the seal. Works like a charm. 5 minute job. Remove linkage, slide tool over the shaft. The tool screws in and grabs the seal. Then you turn a bolt that goes in the center of the tool. It presses on the shift shaft and pulls the seal out. Then tap in a new seal. No more leak. Tool can be had at MATCO or Snap-ON for 25.00. I have one now. Cheers.
Old Jun 23, 2006 | 10:34 AM
CA-Legal-Vette
That sounds like a handy tool to have. Part # or pics please!
Old Jun 23, 2006 | 11:13 AM
knbwag73's Avatar
knbwag73
I just ordered one on-line from Snap-On, part number YA9348, list price is 27.75, free UPS ground shipping.
Old Jun 23, 2006 | 03:06 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
It is my personal experience that the very best way to handle a THM350 shift shaft seal replacement is to yank the transmission and replace the entire unit with a 700 R4..
Old Jun 26, 2006 | 03:29 PM
knbwag73's Avatar
knbwag73
Used the Snap-On tool today, made it into a very simple task.
Old Jun 26, 2006 | 03:33 PM
knbwag73's Avatar
knbwag73
By the way, the whole task took about 15 minutes, which included jacking the car.
To THM350 Shift Shaft Seal Replacement
