dancing volt gage
Old Jun 20, 2006 | 02:14 PM
cherrybomb78's Avatar
cherrybomb78
Default dancing volt gage
what does it mean when your volt gage moves to the directional light, it moves to the lower part of the gage when the dirctional blinks.
wierd!!!
Old Jun 20, 2006 | 03:24 PM
SIXFOOTER's Avatar
SIXFOOTER
means that your signal lights are pulling the voltage down at the voltmeter in the dash. Not necessarily a problem by itself. It does point out however the weaknesses in the wire harness. As long as it isn't going below 12v and assuming the gauge is correct your ok.
The fix is a bit of a rework on the wiring.
Old Jun 21, 2006 | 12:37 PM
cherrybomb78
I did check all the sockets and associated wiring on the directional lights, with no problems found. Could it be just a flasher unit??
Old Jun 21, 2006 | 12:42 PM
mdj21's Avatar
mdj21
could also mean that your gage is getting too old, maybe going bad.
have you tried connecting an analog voltage meter inline with your gage to see if it dances too? (a digital one may not show the fluctuations as well as an analog one will.)
hope this helps,
Mike.
Old Jun 21, 2006 | 12:44 PM
cherrybomb78
I will have to locate an anolog type, you mean with a needle? correct? What would it indicate if the needle dances also, or does not dance??
Old Jun 21, 2006 | 01:16 PM
mdj21's Avatar
mdj21
yea, with a needle. should be able to pick up "el-cheapo" from Radioshack.
if it dances too, your gage is fine. problem is else where.
if it stays steady with the turn signal on, your gage is going bad.
Old Jun 21, 2006 | 02:15 PM
SIXFOOTER's Avatar
SIXFOOTER
the analog meter will show you the same thing your gauge is showing you. Its just indicating the voltage dropping when the lights come on during the flash cycle, this is normal, bring it up off idle and it will not be as noticeable.
Or pull the dash apart and learn some electrics troublechooting with a meter
To dancing volt gage
