Paint Type Question Again, Thanks
Old Jun 20, 2006 | 05:03 PM
72-LT1's Avatar
72-LT1
Default Paint Type Question Again, Thanks
I asked a question a while back about PPG paints and the 72-Bryar Blue color for my car.
Previously the guy at the paint store said PPG only makes Lacquer and Enamel in my color. Well I was in the store buying the $650 in primers and supplies and we looked it up again and PPG has a B/C std color that says bluer. I was told this is not an exact match but is very close just a little bluer?
He said I could go with this color or buy a quart of Lacquer and they could color match to this.
What would be the best? go with the prematched bluer or get a color match from the Lacquers color its only $40 for a quart?
Do you think they would get the color match any closer matching from the Lacquer? I'm already set on PPG paints, well because I bought the primers and the friend doing the painting has an in with this dealer.
Any suggestions are appreciated.
Rob
Old Jun 20, 2006 | 05:29 PM
sray454's Avatar
sray454
I took my car down to the PPG dealer and they used a device to scan and match the color ON the car. Color matched really well, but is slightly different because it is BC/CC.
or you can use the PPG site to look up the code
http://www.ppgcarpaint.com/paints-by...=52&ModelId=52
looks like its 2434
Old Jun 20, 2006 | 07:31 PM
kaamacat's Avatar
kaamacat
72-LT2...... Stich with a PPG urethane base/clear combination, and like was said earlier, these places should be able to make just about anything. The clear will make it a tad darker, so, you might see if they will mix a sample on a spray card with some clear applied.
Be prepared though for the price difference. If you've never gotten into the Urethanes (from old-school laquer) its much more costly to purchase due to the hardeners required.
I also believe you can head out to PPG's site (Automotive Refinishing section I think), and they have nice data sheets on the total prep required. (if you are gonna do this yourself)
Old Jun 20, 2006 | 09:26 PM
CF6873's Avatar
CF6873
Why don't you have the store mix a 1/2 pint of the basecoat and do a spray out and clear it. You then can decide if you like the color or have them leave out some of the dominant blue tint to match the color you want. If they custom match it make sure they document the formula in case you ever need more paint.
Old Jun 20, 2006 | 10:54 PM
72-LT1's Avatar
72-LT1
Thats the problem with matching the color, its a gone from the car. So I guess like the store said I can get a qt can of the laq and have him match that in B/C.
Maybe like spray454 said, they are saying the B/C match for this color is just a little darker, thus calling it bluer. He showed me on the computer, the description says that the color is bluer.
I just don't understand why its not a correct match to the color.
Old Jun 21, 2006 | 09:37 AM
72-LT1's Avatar
72-LT1
Do any paint gurus out there, recomend I just go with the color PPG has set that might not match exact or buy the QT and have them match to that?
Help
Old Jun 21, 2006 | 10:04 AM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Rob
I'd go with matching the original from the lacquer for and exrta $40 it's not a deal breaker.
Old Jun 21, 2006 | 12:41 PM
72-LT1's Avatar
72-LT1
Thats what I was thinking, Im sure no matter which I buy it won't be an exact match if it sat beside one that was in a cave for the last 30yrs
To Paint Type Question Again, Thanks
