Need advice on a 383 build!
Old Jun 22, 2006 | 02:43 PM
  #41
LFZ's Avatar
LFZ
what are the cam specs and CR on that crate?
Old Jun 22, 2006 | 03:22 PM
  #42
72Tornado's Avatar
72Tornado
CR is 10.33:1...don't know the cam specs. Lloyd said that if you opt for the hyd roller, the milder cam they typically use is 224/230, .525 lift, and makes around 425hp. I'm not sure if that dyno graph is from the flat tappet or roller cam though.
Old Jun 22, 2006 | 03:32 PM
  #43
LFZ's Avatar
LFZ
yea, sounds alot like a ZZ383 combo..
Old Jun 22, 2006 | 03:44 PM
  #44
72Tornado's Avatar
72Tornado
Yeah, pretty similar...except with a higher CR, better heads, and a $1000 cheaper if you count the included intake
