clutch alignment question (what X)
Old Jun 22, 2006 | 12:27 AM
mdarney's Avatar
mdarney
Default clutch alignment question (what X)
I was replacing my pilot bearing in my clutch and both of my manuals stated to align the X's on the pressure plate and the flywheel before assembly. Both my pressure plate and my flywheel have been replace. I could not find an X on either one. I did see a painted mark on the pressure plate (yellow) and found some teeth on the flywheel painted yellow also. I used them for alignment purposes. What is the purpose of aligning the X's? Is it a balance issue? I thought both the pressure plate and the flywheel are both balanced prior to installation. The bolt pattern is the same whichever way the pressure plate is turned. My clutch job is not finished yet so I have no idea if I have a vibration or some other problem. Any input is helpful. -Mark
Old Jun 22, 2006 | 11:05 AM
mdarney's Avatar
mdarney
ttt
Old Jun 22, 2006 | 11:09 AM
big_G's Avatar
big_G
The X's would be factory markings, as well as painted. I would line up the painted marks and be done with it. Now go have a beer!...
To clutch alignment question (what X)
