Removing a float
Old Jun 24, 2006 | 02:31 PM
nickc377's Avatar
nickc377
Default Removing a float
I have a 73 and am trying to remove the float but can not get the primary power piston assembly out. I was wondering how to do this.
Thanks,
Nick
Old Jun 24, 2006 | 02:42 PM
...Roger...'s Avatar
...Roger...
Thanks,
Nick
Hold it down and let it spring up several times---you can pry it out but be careful
Old Jun 25, 2006 | 12:14 AM
Rockn-Roll's Avatar
Rockn-Roll
The power piston gets some oxide buildup around it and it doesn't want to come out. But, you don't "need" to remove the power piston just to remove the float. I assume you are just removing the gasket and the gasket is still hooked on the power piston...I'm also assuming that you are going to replace the gasket with a new one...right? Just leave the piston in there and slip the gasket away from it.
Or, is the part you are trying to get out the needle valve? Is the float sitting on top of it? If so, then there is a rod which slides through loops in the float which needs to be removed. A picture of what you are working on would help.
Old Jun 25, 2006 | 11:46 AM
...Roger...
Rock n Roll you have to remove the power piston before you can remove the plastic filler block that is over the float.
Old Jun 25, 2006 | 09:54 PM
Rockn-Roll's Avatar
Rockn-Roll
OK...it's been awhile since I've rebuilt a Q-Jet. Hopefully someone else can chime in that has some recent experience.
To Removing a float
