Engine Hoist Type?
Old Jun 24, 2006 | 06:39 PM
PDsVettes's Avatar
PDsVettes
Default Engine Hoist Type?
I have 73 coupe. What type of engine hoist do most use to pull the engine or engine/tranny: portable or overhead?
Old Jun 25, 2006 | 01:37 AM
Steve COSD's Avatar
Steve COSD
The shark body stlye has a long front end. Make sure the type you use will accomadate this issue.
Steve
Old Jun 25, 2006 | 08:24 AM
fast idle's Avatar
fast idle
if you use the "boom" type, you will need to remove the front tire in order to swing it around,it will not reach in straight from the front.
Old Jun 25, 2006 | 09:56 AM
blctalon's Avatar
blctalon
Use an engine leveler as well if you plan on pulling the engine and transmission at the same time.
Old Jun 25, 2006 | 10:17 AM
oregonsharkman's Avatar
oregonsharkman
I found with my boom lift if I jack up the car right behind the front wheels I can fit the lift where I need it.
Old Jun 25, 2006 | 12:16 PM
JoeRags's Avatar
JoeRags
Old Jun 25, 2006 | 12:59 PM
Jack71's Avatar
Jack71
Originally Posted by JoeRags
Does this model fold up for storage?
I'm so jealous of heavy equipment owners.
Old Jun 25, 2006 | 01:40 PM
gte718p's Avatar
gte718p
Really, tell me thats not cool to just have laying around.
Old Jun 25, 2006 | 06:05 PM
JoeRags's Avatar
JoeRags
folds right up in the corner.
seriously though.. we moved a bunch of years ago to a much smaller house. Since me and my siblings had all moved out to college, there was no room in the garage for my baby. Instead of renting a place, we built two block walls and cornered out a section of our warehouse for the vette (family owns a factory). It is very nice to have access to pretty much anything I need. Full machine shop with bridgport, lathe, welders, plasma, nut/bolt assortments, trucks, etc... and yes, multiple forklifts.
I put that engine in by myself in no time!!!
Old Jun 25, 2006 | 07:28 PM
clive's Avatar
clive
I used a come a long attached to the rafters to take the engine out and body off.
Old Jun 25, 2006 | 07:30 PM
JoeRags's Avatar
JoeRags
I hope you braced across more than one rafter (or ceiling joist, whatever you used).....
Old Jun 25, 2006 | 07:33 PM
77 vette's Avatar
77 vette
Old Jun 26, 2006 | 02:51 PM
clive's Avatar
clive
Oh Yeah, I used a 10' X 1 1/2 steel pipe going across 8 trusses on 16 centers. Blocked it at the strongest points. More than enough for the 1000 lbs needed.
To Engine Hoist Type?
