adjusting rocker arms
Old Jun 26, 2006 | 02:25 PM
rgreensides's Avatar
rgreensides
Default adjusting rocker arms
Just rebuilt 454 (73 vette). I have read and heard different opinions on adjusting the rocker arms.(hydraulic lifters) Some say take the slack out and then turn the adjusting screw 2 full turns, or 1 1/2, or 1 full turn. Any thoughts or opinions on which is correct??
Old Jun 26, 2006 | 02:28 PM
zwede's Avatar
zwede
GM recommends 1 full turn. Using 1/2 turn or 3/4 turn gives you a few hundred more rpm before lifter pump-up. If the motor is mostly stock I'd say the GM spec is a safe bet (1 full turn).
Old Jun 26, 2006 | 03:08 PM
knbwag73's Avatar
knbwag73
Go with the GM spec, 1 full turn, you should not have to touch them again.
To adjusting rocker arms
