tapping sound...
Old Jun 25, 2006 | 11:45 PM
KevsC3's Avatar
KevsC3
6th Gear
Default tapping sound...
Hey all,
I need to see if anyone can help me pin point this noise to exactly what it could be...
During idle, the engine idles fine, however, every now and then it will make a tapping (or even a knock) sound like a bent push rod, its intermittent though, it's like "tap.........tap..tap....tap............ ..............tap......tap"
then if you slightly press the gas, it will go
"tap..tap...tap......tap.......tap...... ...............tap...................... ....tap..tap........tap.tap..tap...tap.. .tap"
then if you go back to idle, you may not hear it for over 2 minutes before it begins and then stops for a while...
the engine did run a little while without oil, the gauge was not working, I added oil and let it run, still same thing.
I took the pushrods out and none are bent or appear to be.
any ideas I hope you can understand from this post lol
Old Jun 25, 2006 | 11:55 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like a lifter bleeding down a bit
Old Jun 26, 2006 | 08:18 AM
a1sensei's Avatar
a1sensei
A mechanic's stethoscope is a great $10 investment. If it is a lifter, and it sounds like it is, you can take off the valve covers, put the probe on the rocker studs and find which one it is. (It might just need adjustment) God bless, Sensei
Old Jun 26, 2006 | 01:21 PM
KevsC3's Avatar
KevsC3
6th Gear
Thanks for the info!
If I get a mechanic's stethoscope, I can put it on on the studs while the engine is running? With the valve covers off, would'nt oil shoot out everywhere? DO I turn the engine on or something else?
thanks
Old Jun 28, 2006 | 08:35 PM
roger55's Avatar
roger55
They make clips to for the rockers so they won't spray, but you still will probably drip a little oil.
Another trick is to cut the top out of an old valve cover and bolt it on.
Old Jun 28, 2006 | 08:55 PM
JoeRags's Avatar
JoeRags
It could also very well be an exhaust leak... do you have aftermarket headers on the car?
take a look around for soot.
Old Jun 28, 2006 | 08:59 PM
roger55's Avatar
roger55
Good point.
Also check for loose bolts on it whether it be headers or stock.
(Loose bolt = bad gasket)
Old Jun 28, 2006 | 11:09 PM
Sayfoo's Avatar
Sayfoo
I had this from a cracked cast iron exhaust manifold. Brased it, and ran it for 8500 miles, worked great.
Old Jun 29, 2006 | 09:30 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
A bad lifter...broken rocker arm...try to isolate the tap....a rocker could be whacking the valve cover....look close for dents
To tapping sound...
