Vertical Distributor Movement (Points)
Old Jun 26, 2006 | 09:24 AM
71-Triple Blk's Avatar
71-Triple Blk
Default Vertical Distributor Movement (Points)
Can someone advise on the amount of vertical play I should have when lifting up and down the centrifugal weights? The internal shaft seems to have about 3/16" slop up and down - it rotates a bit so the gear is engaged but I am not sure if this vertical movement is causing me issues at engine speed.
Thanks!
Brian
Old Jun 26, 2006 | 09:27 AM
David Ey's Avatar
David Ey
You need to remove the dist. and shim between the gear and housing to get aprx. .003 to .010 clearance. You can buy a shim pack to do this.
