First, the tip: I found an easy way to hang on to the big bolt on the driver's side lower control arm which is blocked by the power steering pump. I took a 6-point socket that would fit into the gap and onto the bolt head, then clamped HARD onto the socket with a Vice-Grip. The first two attempts I didn't have the Vice-Grips tight enough, and the socket spun. After that, the electric impact wrench made short work of removing the nut. Huzzah!
My Energy Suspension bushings came with the bushing, inner sleeve and outer shell pre-assembled. The instructions say to grease the bushings before assembling the three parts. Are these things pre-greased or should I take them apart before installing? How can I get them apart? They seem fairly stuck in place.
The factory big washers on the cross-shaft end bolts have a dished shape at the edge. Do I need to replace these with the identical style, or will flat fender washers be OK?
1. The ES poly bushings are floating (non-bonded) will pop apart with stiff finger pressure. OE type rubber shell-bushing-sleeve is bonded as one discrete assembly ... poly is not.
2. Use plenty of silicone grease when assembling these parts to shafts ... you can get a squeeze tube of silicone dielectric grease at parts store for a coupla $.
3. I'd use the dished washers. Since you are using a floating (non-bonded poly) bushing & floating inner sleeve ... you cannot torque the end bolts down against the inner sleeve ... and expect bolt to stay there ... it won't! It is VERY important that the threaded holes in ends of shafts and the end bolts to be XTRA clean. Clean out holes with a tap ... use new bolts. Then, near last thing you do is to blow out those holes with carb cleaner & clean bolts same ... this to get any trace of silicone grease out of threads/holes. Then, after all holes & threads are squeaky clean & DRY, then install the end bolts with LOCTITE ... this cleaning, drying & loctite is VERY important with poly. If end bolts come loose, the non-bonded (floating) bushing will be spit out the ends and your alignment will change REALLY REALLY quick ... as in HANG ON!
Thanks - I've tried hand pressure to push the bushings apart, they're pretty tight. I'll try again tonight. Loctite is a must on everything.
If your old outer shells are still in place in arms ... and still in good shape ... and the old rubber is cleaned out of them ... you can simply install the new poly bushing and new inner sleeve into existing, clean outer shell ... no need to cut out or press out the old outer shells when fitting with poly.
The old shells weren't in very good shape, and have been chiseled out. Not that I've been having much luck getting the new bushings out of the new shells...why the heck did ES pre-assemble these things???
