Rear bars add oversteer---you cannot cure an existing oversteer problem by adding a rear bar, it will make it worse.
Now that's the kind of input I'm looking for. Based on your experience I beleive that. I guess I need to get it back together and have a guy like you go for a ride with me.
I'm not looking to band aid. I just didn't know. Thank god for this forum!!!
If any car is unstable and I wanted to fix it. Do the simple stuff first. you have to have good - shocks, springs, ball joints, steering parts, and A-arm bushings.
In a straight line on a smooth road sway bars are not helping or hurting anything.
I've driven some fast door slammer type drag cars and they don't feel at all safe to me when you let off of the gas after the lights. Their problem is wallowing big rear slicks without much air pressure and 4 link solid axles were only made to work under power. Well little skinnies on the front don't inspirer much turning confidence either
It's got new shocks (all 4), new springs, all new bushings. However, I don't know of the condition of the ball joints. What would be a good check for play in them? I also did check the steering rag joint and there is a little play in it. But would that have that effect?
My rear tires are only 10" wide, so that may or may not have the effect you are talking about. Lucky you getting to drive those door slammers!!!!
I do run coilovers so my car might be different but I found a rear bar really stabalized the car. Even helped the darty feeling in the front end and particularly helped the high speed breaking.
I do run a huge 1 1/4 inch rear speedway bar.
I also found it makes the ride alot rougher but again it really stablized the car.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by Van Steel
Rear bar size should be determined by what front bar you have. With these rear bars you should match up a new front bar with it as well. What works best together is
1" Front 5/8" Rear
1 1/8" Front 3/4" Rear
1 1/4" Front 7/8" Rear
Anything over an 1/18" Front & 3/4" Rear will be pretty stiff. Using unmatched front & rear bars can cause over or understeer depending on which bar sizes you are using.
I don't know that I agree with this formula. It's not taking into account the f/r spring contibution to the roll stiffness. I have the 1 1/8 inch front bar with 550# front springs, but as I continued to increase the rear spring rate I ended up deleting the rear bar. For the past several years I've had the roll stiffness I like, a minimum of rear squat, and the deletion of the sway bar weight.
I'm no suspension expert, but I don't know if I agree with the sway bar combo's either. Too many variables,..primarily front-end weight. A BB car with A/C, pwr steer, pwr brakes, will weigh 300 pounds more than a SB car with no A/C, no pwr brakes and/or no pwr steer,..and most this weight is concentrated up front (on the BB example),..which would require a stiffer sway bar up front for sure.
But out back, I'm not sure there would be a big differerence in sway bar needs of the two examples above, since again, most the weight difference is concentrated up front.
Guys why don't you ask the car?? Bolt one on and give it a try. If you really want to work out combinations you have to spend some money. It isn't that expensive to buy a bar, bolt it on and try it for yourself.
I have done up to 3 front spring changes in a day just for testing, sure it costs, gives you good experience.
I agree there are many many different variables out there to consider which bar might be best for you. It does depend on what options your car does have and it does depend on what goal you are trying to achieve. The bar sizes listed above are a general idea of what works best together, but again you have your different variable. Some guys like stiff sways and soft springs some like the opposite. Thats why it's best to call us so we can get idea of what your trying to achieve. You will also note that just about every vendor that sell aftermarket bars will have them list like I did above.
The quickest check on ball joints for our old Vettes is:
If they still have the rivets (not nuts) they are the original and they should be replaced.
Grinder or heat them with a torch and knock them through. Just be carefull not to damage the A-arms. MOOG makes a good set.
If I remember correctly they are the stock ones. The new installation sounds easy enough. I geuss I've got something else to add to the list before I can run it again! Thanks!
Set me straight if I'm not thinking clearly.
Hmmm. That's got me thinking. I've removed a lot of weight off the front end. Maybe my front bar is over/under what it should be now too. I wonder how in the heck I could know whats best short of buying and installing all of the different combos as norval has suggested.
I think your best bet is to start with GKull's advice and then go to play with sway bars like Norval recommends.
You can't be scientific about this if the bushings are shot - there will just be too many variables at that point. It sounds to me like you have some rear suspension trouble - probably shot strut rod bushings or trailing arm bushings(actually, more than likely it's both). Also, how's your alignment doing? That should be checked out too. Go to a good alignment shop and let them know what purposes you're driving the car for.
I have new "Smart" struts, new trailing arm bushings and shims. Front to rear alignment had been done about 2 months prior. The problem only showed its self when I was testing out the nitrous. I did a few back street test runs up to maybe 100 m.p.h. As soon as I let off it got all "darty".
What about your motor, trans, & diff mounts, and drivetrain geometries? A loose or misaligned drivetrain can cause handling abnormalities.
Just a thought.....
So does that mean it was aligned after the new rear end parts, or before?
