Fuel sending unit replacement
Old Jun 28, 2006 | 12:26 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default Fuel sending unit replacement
I have been looking around online and see that for a 78 model you can replace the fuel sending unit through the top without dropping the tank. Can the rear pace car spoiler be left in place or does it need to be removed to do this?
Thanks,
--Chris
Old Jun 28, 2006 | 01:07 PM
Paul L's Avatar
Paul L
Dupe removed.
Old Jun 28, 2006 | 01:08 PM
Paul L's Avatar
Paul L
I may be wrong but I can't see how you can get that unit out through the gas fill pipe. You have to loosen the cam lock underneath in any case so why not just take it out the bottom. The gas tank does not have to be removed.
Old Jun 28, 2006 | 03:20 PM
St. Jude Donor '09
My unit looks completely different than what you have pictured there, on corvettefaq.com there is an article showing how to remove it from the top, but I wanted to know if i needed to remove the pace car spoiler or not.
Thanks,
--Chris
Old Jun 28, 2006 | 05:53 PM
hunt4cleanair's Avatar
hunt4cleanair
Chris
If you can lift the lid to refuel...you can remove the lid assembly and access the sending unit. As I recall the spoiler rides underneath the lid opening.
Old Jun 28, 2006 | 07:46 PM
Paul L's Avatar
Paul L
My apologies if I gave you bad advice.
Old Jun 29, 2006 | 09:00 AM
bluesilver82's Avatar
bluesilver82
In my 82 the sending unit is easy to replace. Just remove the lid, bezel and boot. Unbolt the unit, turn and lift out at an angle. Reinstall in reverse order. Takes less than 30 minuites to remove change the pump and reinstall.
To Fuel sending unit replacement
