steering adjustment 1980 c3
Old Jun 30, 2006 | 01:29 AM
bloater's Avatar
bloater
Default steering adjustment 1980 c3
hi guys,
in a bit of trouble with my steering,left car at repairers to replace ball joint off pitman arm on steering cylinder,he had it apart & now the steering throws itself to one side.got car back now and sortin myself.
can any body tell me how i adjust this cylinder. i can get perfect power assist on one side but then the car wants to steer itself to the other.really desperate with this now. thanks
Old Jun 30, 2006 | 08:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Not sure I understand your situation, but it sounds like your mechanic has reversed the hoses to the cylinder. Check the hose routing from the pump to the cylinder.
Old Jun 30, 2006 | 08:12 AM
SIXFOOTER's Avatar
SIXFOOTER
steering control valve is what your after. the business end is just behind the drivers side front wheel. Jack the front wheels just off the ground. Remove the cap on the end of the valve, start the car. Adjust the screw in until the wheel starts to move, stop and note the position. Adjust out til the wheel starts to move, stop and note the position. Now go back in to the center between those points and you should be good.
Old Jun 30, 2006 | 08:31 AM
Higs's Avatar
Higs
Make sure the steel lines cross each other at the control valve.
Old Jun 30, 2006 | 12:34 PM
cmac72's Avatar
cmac72
Turn the adjusting screw slowly because of a time delay you'll find the rod will start moving all of a sudden in the other direction. If you keep going back and forth you will eventually ruin the adjusting mechanism.
Old Jun 30, 2006 | 12:50 PM
kevinator80's Avatar
kevinator80
If he had the valve apart for a rebuild, you will get an all to one side or the other reaction if he got the seal and spacer in reverse order. Don't ask how I learned this.
Old Jun 30, 2006 | 12:53 PM
cmac72's Avatar
cmac72
And......if you just replaced the cylinder the PO cut out with a sawsall and threw away and had your car still up on ramps, be careful when you start the car just in case the wheels turn hard one way or another......gives a whole new level of excitement to an otherwise uneventful day.
Old Jun 30, 2006 | 04:01 PM
bloater's Avatar
bloater
many thanks for the info guys.fitted a replacement cylinder now,so i know its definately piped up correctly.i am now in the following situation
perfect power assist on left lock,very stiff on right lock.at idle the wheels stay straight and also when i build up the revs a little,however when you pull it in drive & accellerate,it pulls over to the right.Ithink now it is purely gonna be down to fine adjustments of th nut on the end of the cylinder(I hope).if not i will have to settle for driving round in circles lol.again many thanks for your replies.not always easy to get good info here in uk,its appreciated
Old Jun 30, 2006 | 06:42 PM
galvestonVETTE's Avatar
galvestonVETTE
Higs, what happens if they get crossed?
Old Jun 30, 2006 | 08:15 PM
Jim Shea's Avatar
Jim Shea
With respect to installing the power steering lines incorrectly, you get a beast that thrashes around and wants to steer itself.
With respect to your original problem. Normally I would say that you have to adjust the control valve. HOWEVER, you say that you didn't touch the control valve, just a new assist cylinder. Changing the cylinder shouldn't cause the control valve to go out of adjustment. This leads me to think that you may still have some air trapped on one side of the cylinder. I would jack the front end up and rotate the steering wheel lock to lock a couple dozen times - WITH THE ENGINE OFF! Check to see if your fluid level in the reservoir goes down a bit and look for any air bubbles coming up into the reservoir. Refill if needed.
Jim
Old Jun 30, 2006 | 08:36 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Don't have an answer for you, but all I can say is 80's rule all.
Old Jun 30, 2006 | 09:12 PM
Maymyvetteliveforevr's Avatar
Then '75's Rule All Bitches!
To steering adjustment 1980 c3
