Rear end ratio
Old Jun 30, 2006 | 07:25 PM
KJones's Avatar
KJones
Default Rear end ratio
How many differential ratios were available in 1979?
Ken
Old Jun 30, 2006 | 08:04 PM
Little Mouse's Avatar
Little Mouse
In 78 they were 3.08, 3.36, 3.55, 3.70 I doubt the 79 model yr was any different.
Old Jun 30, 2006 | 08:10 PM
KJones's Avatar
KJones
Thanks,
I just crawled out from underneath it and am betting it is 3.55
I just swapped the TH350 for a 2004r and need to work on the speedo calibration.
Thanks again!!
Ken
Old Jun 30, 2006 | 09:46 PM
BerniesVette's Avatar
BerniesVette
With the rear wheels off the ground and the shifter in neutral. place a piece of tape on the drive shaft and a piece on a tire. Have someone rotate the tire exactly one full turn and count the revolutions the drive shaft makes. 3 1/2 is 3:55 to 1 rear ratio, etc.
Bernie
Old Jun 30, 2006 | 11:47 PM
KJones's Avatar
KJones
That's precisely what I did Bernie...
Thanks for the help
Ken
Old Jul 1, 2006 | 07:20 PM
82Vette'ster's Avatar
82Vette'ster
If you have to change the drive gear for the speedo, it probably would have been easier when the trans was out. I had to change the speedo gears on the 700r4 when I went to 3.73. It was hard to get at the drive gear, ended up pulling the trans cross member off to get at it.
To Rear end ratio
