4 link question
Old Jul 1, 2006 | 01:09 AM
panchop's Avatar
panchop
Default 4 link question
Any of you folks running a 4 link rear. What are you doing for lateral tracking. A panhard rod would be to short. My kit came with a diagonal track locator but it seems to be mighty close to the pinoin yolk when mounted on the lower connecters. I could mount it on the upper bolts of the 4 link but I think that would raise my Roll Center to high, correct. I was thinking of fabricatiing a wishbone type locator as I belive that would clear my pinon yolk and still allow me to mount it low. any advice?
Old Jul 1, 2006 | 02:43 AM
tfi racing's Avatar
tfi racing
If you are running a 9 inch rear, a J bar panhard may be an option.
Old Jul 1, 2006 | 03:10 AM
Little Mouse's Avatar
Little Mouse
Default Roll Center
Cant see how roll center would be a problem you are no longer
going around any corners with what you have now.
Old Jul 1, 2006 | 07:11 PM
panchop's Avatar
panchop
I don't know what a J bar panhard rod is? It's true I'm not using this to take corners at more then a crawl but I don't want a twitchy unstable beast in the big end of a run. The better I can make it " handle " the better it will act if I can get it to hook. Stoping too, stoping straight would be good.
Old Jul 1, 2006 | 07:25 PM
Twin_Turbo's Avatar
Twin_Turbo
IMO the best system is a diagonal track locator bar from the frame hinge point to the other sides axle hinge. that way you divide it in 2 large triangles and triangles are the sturdiest geometryc shape. It only takes 1 bar and 2 rods, very simple.
A wishbone is also possible but more work and less effective.
Old Jul 1, 2006 | 07:46 PM
Little Mouse
Default picky
I swear some people are just picky, you want to go in a strait line
and be able to stop without getting squirrelly. What about all the
old alterd short wheelbase strait front axle cars or stone/woods/cook
41 ****** they did not worry about getting squirrelly.
Old Jul 1, 2006 | 09:04 PM
aussiejohn's Avatar
aussiejohn
Default Watts linkage
Panchop,
What (Watt??) about a Watts linkage? They have been standard fitting on many production cars as well as race cars. I'm presuming you've ditched the IRS in favour of a live axle.
Regards from Down Under
aussiejohn
To 4 link question
