Hedmann Header install problem.....
Old Jul 1, 2006 | 07:21 PM
patdrums's Avatar
patdrums
Default Hedmann Header install problem.....
Finally, I have the motor in the car now and am getting closer to having this puppy running....
Short rundown...
74 Coupe/350/3 spd. auto/AC
Went with Hedmann Headers on a recommendation from someone here and just tried to dry fit them and get a look at how they'll fit and I seem to be running into a problem....
It looks like the forward-most pipe in the cluster is going to bump into the idler arm/frame attachment on the passenger side before I can get it into the proper position to bolt on. (Haven't cheked driver's side yet) I tugged and pulled and tried to get it to all line up but it looks like I'm gonna be about 1/2" to 1" short of making the fit and the only place I can see anything rubbing is at the idler arm.
Anyone run into this or have any suggestions on how to make it work? I don't really want to take a damn hammer to the headers if I can help it (and certainly don't want to bend the pipe too much and end up restricting the airflow) but my initial impression is that these headers may not work and I may have to swap them for something else. Anyone?.......
Pat
Old Jul 1, 2006 | 07:37 PM
Bob Onit's Avatar
Bob Onit
Time
I realize it will breathe better than the stock manifolds.
I had Hooker headers on my first 73' and it wasnt worth the headache.
Burned up starters, hard to change starters,hard to get at certain spark plugs, way too hot in the cabin (get your asbestos boots out)
I realize you have spent $$ on the headers and for a good reason........ Me, Ill stick with stock manifolds unless I decide to go with Side Exhaust
I wouldnt take a hammer to them until you exhaust all your other options.
Old Jul 1, 2006 | 08:40 PM
Little Mouse's Avatar
Little Mouse
Default angle wrong
Have you put the header in with the flange at the same angle as the
head exhaust ports. Maybe you just need to pull the collecter in
more toward the middle of the car and go forward then bolt it up??
Old Jul 1, 2006 | 09:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it will be right up against that idler arm.....almost to the point of preventing you from changing the idler arm....to put these in you need to think outside of the box..... get the car jacked up pretty high and and put them in from the bottom...on one side on my car i had to start with the collector end facing the front of the car and rotate the headers up in to place....... just keep changing the angles and all of a sudden it will be in place.
Old Jul 1, 2006 | 09:33 PM
aussiejohn's Avatar
aussiejohn
Default clearance
G'day,
My '74 had headers on it when I bought it and one pipe on the pass side is dimpled to clear the idler arm, so I suspect that this is a problem with many headers.
I'm guessing that they were made for Camaro/passenger cars and because the engine is the same as a Corvette, the vendor will tell you " that they'll fit a Corvette..."
There must be plenty of owners though who have a set that clears the idler arm, and this is the forum to find out what brands fit without clearance problems.
Any takers?
Regards from Down Under
aussiejohn
Old Jul 1, 2006 | 10:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
YOu have to go in from the bottom as bobs77vet's stated. Jack as high as it will go and then try and find the correct angle and they will go in.
Old Jul 1, 2006 | 11:07 PM
vettenoir's Avatar
vettenoir
I had to dimple the header slightly to clear the idler arm.
Old Jul 1, 2006 | 11:59 PM
Artsvette73's Avatar
Artsvette73
I have hedman headers on my 73. They went in with no problems. What condition are your motor mounts in? Just a thought
Old Jul 2, 2006 | 10:36 AM
The3's Avatar
The3
My 74 has a set of Hedman Headers and they clear. The top bolt of the idler arm bracket was shortened though. I just pulled the passenger side header and it was tight. I think your good on fitment but just need to finesse them in.
Old Jul 2, 2006 | 12:01 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Exactly the way mine went in. I was wrestling, banging and forcing to no avail. Then like magic, KABLAMO, they were sittin in place.
Old Jul 2, 2006 | 12:45 PM
PRNDL's Avatar
PRNDL
Different year, different engine, different headers (hooker supercomps on 68 bigblock) but....... same problem!
My headers made a very slight contact with the idler arm, sounds like less than yours. I was actually able to move my idler arm slightly (there is a small adjustment possible) which was enough to provide clearance.
Old Jul 2, 2006 | 01:26 PM
682XLR8's Avatar
682XLR8
Ran out and looked at my set-up just to be certain before I post....
I am using Hooker Comps 1 5/8 tubes, drivers side is about 1/2 from the steering box, pass side is about 3/4 away from the idler arm, no problems with plug clearances, very good-fitting header
If you bought your Hedmans from Summit, they should exchange with no problems if you can't get the Hedmans to work
Old Jul 2, 2006 | 09:12 PM
supervette2's Avatar
supervette2
I had hooker comps too and they also had good fitment with the 1 5/8. Defintily go from the bottom it takes a couple angle approaches to get them in there but they will slide up there. Ive taken them out a couple times and it gets easier everytime. I had no starter problems or anything of that sort.
Old Jul 2, 2006 | 10:26 PM
jeckel's Avatar
jeckel
I have a set of hooker super comps in one of my 74's. You have to go from underneath as everyone has been saying. It may take you a little bit to get them in but they will go in.
Old Jul 3, 2006 | 01:18 AM
fauxrs2's Avatar
fauxrs2
Here is a shot of my hedmans on the passenger side.... as stated before - coming up from below makes install a no-brainer...
Note the proximity to the idler arm...I dimpled (very slightly) for clearance from the rubber boot on the idler .. other than that no problems.
Old Jul 3, 2006 | 02:18 AM
VetteLS6's Avatar
VetteLS6
The headers are running with a AIR pump?....dang I would remove that junk.
Larry
Old Jul 3, 2006 | 02:31 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I'm using hedmans and they fit. I dimpled the header for the idler arm but it turns out, that was not necessary.
To Hedmann Header install problem.....
Old Jul 5, 2006 | 11:26 PM
fauxrs2's Avatar
fauxrs2
Larry
Not permitted if I wish to keep the car registered
Old Jul 5, 2006 | 11:45 PM
Ak. Mal's Avatar
Ak. Mal
Did you add the A.I.R. to the headers or did you find a set like that for sale?
Old Jul 6, 2006 | 12:19 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I had some Hedmans on a small block once and I gotta say IMHO they fit terrible! There is so much room to run the pipes corectly it's insane. Their Big Blocks ones fit fine, but the small blocks are tight where they shouldn't be and hang way too low..or at least a lot lower than needed.
JIM
