Aux cooling fans
Old Jul 2, 2006 | 10:43 PM
Gary B.'s Avatar
Gary B.
Hope you can figure out the fix. I am waiting to get my car out of the shop after I overheated it 4 weeks ago. It was running approx. 230 degree. The car started to loose power, and by the time it got to the shop number 8 piston had scuffed. I am getting ready to install a aux fan from a 1981, replacing the bottom air dam to see if it helps, a bottle of water wetter, and a new 180 degree If not, no a/c. Gary B.
Old Jul 2, 2006 | 11:21 PM
ThunderMaker's Avatar
ThunderMaker
I wouldn't waiste the 8.99 on water wetter....I haven't read one post yet that claimed the stuff actually works !
Old Jul 2, 2006 | 11:26 PM
MikeC's Avatar
MikeC
Originally Posted by Capt. Ron
Upper hose read 200's, thermo housing 215, bottom radiator hose 170's.
Your rad is working fine by the looks of the temperature differential. I would look at your thermostat it may not be openning at the right temp or may be sticking. Also feel to see if your lower rad hose has a spring in it.. if it collapses, it limits water flow to the engine, causing it to run hotter.
As an FYI, my Griffin Alum. rad has a 22 deg differential (179 upper hose to 157 lower hose, 205 at the temp sensor). This is with an undersize electric fan only. I run 60% water and 40% antifreeze with a bottle of water wetter. I run 195-198 at highway speeds with 3.70 gears, and just over 200 in town(bigger fan will solve that).
Old Jul 3, 2006 | 09:23 AM
ESU's Avatar
ESU
Mike,
you run hotter in the city and cooler on the hi way as would be expected. Myself and Capt Ron as well as a few others run it just the opposite and thats what has us confused. I can run all day around twn with the a/c on and never go above @200. On the hiway at 65mph or under I'm fine also. It's that 70 mph mark that kills me.
ESU
Old Jul 3, 2006 | 09:38 AM
SIXFOOTER's Avatar
SIXFOOTER
ESU, it sounded like your radiator is working from what you said about the temp diff from top hose to bottom. You have plenty of air flow with the fan mods and air dam mods. It sounds to me like you either have flow restriction in the heads or you may need an oil cooler. You can get an inexpensive oil/tranny cooler from summit to give it a try, or for about $200 they have a oil+tranny cooler with a fan that will do the job. I like that one but ain't payin that, so I am going to make it for about 1/2 that price with all new parts.
Getting tranny temp would be a good idea, if your not locking up it would add a lot of heat to the tranny oil. There are some tranny temp gauges of different stripes on summit/jegs etc..
Old Jul 3, 2006 | 10:04 AM
ESU's Avatar
ESU
Sixfooter,
I'm with you on air flow and water flow. With a brand new engine I cant believe there is a restriction in the heads. I'm also with you on the 200 for that fan/cooler combo, somebody may call me cheap but unless I'm 100% positive its gonna work then its out. Just like the 500 buck alum radiator. WHen I installed the new motor I didnt change the converter, just left in what was in so I have no idea if its working properly. Taking the tranny temp would probably be a good idea, whats one more gauge laying around. I actually have an extra analog water temp gauge laying around, I wonder if I can use that and if so where do I tap in??
ESU
Old Jul 3, 2006 | 10:49 AM
SIXFOOTER's Avatar
SIXFOOTER
This is one way to do it;
http://store.summitracing.com/egnsea...rdSearch#rstop
Not sure what I would use.
Cyberdine makes temp sending units you can hook to multiple points and use a switch to check them. I was looking at a temp differential gauge somewhere, has 2 temp sensors and reads the difference between points, was like $59. I want to use one to look at oil cooler and trans cooler temps and use a switch to select one or the other and use 1 gauge, might put it on the rad too and use a 3 way switch. Would go a long way to answering some questions.
I missed the part about the new engine on your post.
figure out which line on the tranny is OUT and put a T on it and oput the gauge there, the temp coming out of that point will tell you whats going on. If you have a IR Temp gun use it on the tranny pan after a run and on the oil filter.
Old Jul 3, 2006 | 11:02 AM
ESU's Avatar
ESU
I have an IR gun but not too confident in it's use. Shoot one spot its 230 deg, 1 inch over is 220. Hold it 3 inches away u get a different reading as opposed to 4 inches away. I think I'll try the tranny cooler, whats another 40 bux? Capt Ron what says you??? You started this thread, tranny cooler or we just stay under 65mph til we can afford a 4 speed overdrive tranny???
Happy 4th of July to all, ESU
Old Jul 3, 2006 | 02:31 PM
Blue79's Avatar
Blue79
Been following these posts, as my 79 has the same symptoms. Just had the carb rebuilt and plan on installing trans cooler after checking/adjusting timing. I believe the proper way for trans line hookup to radiator has the return line to the lower fitting so air gets pushed out. Confirm?
Old Jul 3, 2006 | 04:20 PM
Capt. Ron's Avatar
Capt. Ron
I don't know what my next step is, would do a tranny cooler but will have to research where to put it. Don't know about putting anything else up front. Somewhere on one of the other threads, I did read that someone did a tranny cooler, put it up front and he said it solved his problem. Maybe we can start a new "Tranny cooler" thread and get some ideas.
Happy 4th
Capt. Ron
Old Jul 3, 2006 | 04:39 PM
ESU's Avatar
ESU
Happy 4th
Capt. Ron
I dont see why we cant, somewhere on this forum a member has found the ideal location to install a cooler. Thats the purpose of forums, somebody , somewhere has had the exact same problem before you did, thats what makes it great. I also dont believe up front is the best idea. I know Bangkok Dean installed his there. Summit has remote frame rail mounted coolers, that may be a start. My only question is do you eliminate the hot tranny fluid runing thru the rad or use both??
ESU
Old Jul 3, 2006 | 04:40 PM
ThunderMaker
Wow, I'd sure like to know if you can confirm that the tranny cooler solves the problem...keep us posted Cap't Ron, I too live in GA so we run our cars in similar climate temps. It looks as though there are several of us, based on this string, who can benefit if one of us gets this figured out! I am switching to synthetic oil to see if that helps at all.
Old Jul 3, 2006 | 05:26 PM
  #33
BerniesVette's Avatar
BerniesVette
I think Bancock Dean installed his tranny cooler in the area behind the air dam laying horizontal covering the opening underneath. While I had an automatic I mounted a large tranny cooler in front of the A/C condensor and it did help. I finally installed a 5 speed manual and the overdrive, plus eliminating the 180 degree heater sitting in the tunnel, helped trmendously. It helps to get those rpm's down while cruising too!
Bernie
Old Jul 3, 2006 | 06:02 PM
  #34
Capt. Ron's Avatar
Capt. Ron
Will start the "Tranny Cooler" thread now.
Old Jul 3, 2006 | 09:25 PM
  #35
Gary B.'s Avatar
Gary B.
If the problem is lack of water circulation above a certain rpm because of the fan clutch disengaging, what about running with out the clutch with a flex fan? I know you would be sacrificing some hp but it might be a good trade, and I know it would be a heck of a lot cheaper that replacing parts because of overheating. Gary B.
Old Jul 4, 2006 | 04:32 PM
  #36
Capt. Ron's Avatar
Capt. Ron
I thought of that and bought a fan tower to eliminate the fan clutch all together but the one I bought had a different bolt pattern and I never got it installed. HUM!
Bye the way, I am newer to this forum and started a kinda "cross-thread" to this thread entitled Tranny coolers, where to put them. That may have not been the way to go as it maybe somwhat confusing.
Sorry, but if you have this problem or your interested check out that post also.
Capt. Ron
How do you work the spell check???????
Old Jul 4, 2006 | 09:04 PM
  #37
BerniesVette
The fan clutch has nothing to do with water circulation. The water pump turns via the belt on the pulley. The clutch is between the water pump and the fan. The clutch disengages the fan above 2800 rpm because you should be moving fast enough to force air thru the rad above that rpm; except that the slanted rad will allow air to flow over it rather than thru it without help. Completely sealing the area around the rad and rad support help force air thru the rad. Electric fans will also pull air thru the rad after the stock fan has stopped turning. There are so many things that are critical to our C3 cooling system that one left out will cause you to have a heating problem.
Bernie
To Aux cooling fans
Old Jul 4, 2006 | 09:24 PM
  #38
ThunderMaker
I had a flex-a-lite flex fan on my c3 for a couple of years after th eoriginal clutch failed. I thought that I was buying newer technology and it would cool better. It awas noisey as hell and I really am glad its gone !
Old Jul 4, 2006 | 09:34 PM
  #39
Capt. Ron's Avatar
Capt. Ron
I think if we get the right people to read our posts, there is an answer out there? Just have to find them.
Had to get out of the pool, had to pee.
Happy 4th
Capt. Ron
Old Jul 8, 2006 | 12:47 PM
  #40
ThunderMaker
Default Pulled Tstat out...no more problem !
Pulled Tstat out...runs 30* cooler on Hwy and around town...
