lockup torque converter
Any information would help thank you,
Because slip within the torque converter reduces efficiency and may generate excessive heat, some converters incorporate a lockup mechanism: a mechanical clutch that engages at cruising speeds to physically link the impeller with the turbine, causing them to rotate at the same speed with no slippage.
The first automotive application of the lock-up principle was Packard's Ultramatic transmission, introduced in 1949, which locked up the converter at cruising speeds, unlocking when the throttle was floored for quick acceleration. The demand for increased automobile fuel economy brought about a gradual but widespread application of the lock-up converter for automotive transmissions between the late 1970s and mid-1980s.
