BeCool radiator question
This year, I added the Spal fans. My primary reason for that was to get rid of the stock shroud for clearance. Now pulling the radiator and fan is a 15 min job. I got my fan kit from BeCool including mounting brackets and wiring harness. It is wired with a thermostat on at 195, off at 175. It will turn on and off in town, on the highway, it won't even turn on usually unless really hot then stays on. However, at speed, the current draw is less due to airflow.
Does it work. This summer I drove cross country in July. CO, KS, MS all over 100 degree days. Cruised at 70 mph plus and never broke 200 on the gage.
Other issues: I run a 180 thermostat. As for the load on the alternator, go to http://www.alternatorparts.com . I got a kit for $24.95 that converted my stock 42 amp alternator to an 85 amp alternator. Took about 45 minutes to do the job.
BTW, alternator is always charging to one extent or another. Won't hurt it one bit.
With 2 10" fans I rarely get over 200 even in traffic. If it does, a third fan kicks in at 205 and the temp really drops to 180 fast. If you are using a shroud, you will not need a third fan. Zwede is using your configuration on an air conditioned big block car to great success.
BeCool radiator and Spal fans do a great job!
Chuck
p.s. I suspect your thermostat is not working properly if you are running 190 on the highway. Was it accidently installed upside down? Your small block should be able to run at least as cool as my big block with the same thermostat.
[Modified by Chuck Harmon, 11:02 PM 8/31/2001]
