caliper piston removal
Old Jul 4, 2006 | 02:02 PM
Lucky68's Avatar
Lucky68
Default caliper piston removal
Hey,
I have my caliper off, and the halves are split. I want to take off the boot, how do i do this without ruining it? It seems like it is melted on the the insert that is in the caliper. do i just rip it off to get the piston out?
thanks
Old Jul 4, 2006 | 02:07 PM
Duke94's Avatar
Duke94
The boot has a metal ring overmolded around it. It then gets pressed into the caliper housing. Almost impossible to get them out w/o damage. They should be replaced anyway.
Old Jul 4, 2006 | 02:11 PM
GaryS's Avatar
GaryS
Originally Posted by Lucky68
Hey,
thanks
Typically, you can't remove the piston without damaging the boot. I always replace the seals, both the boot and the inner "doughnut" seal, every time I open a caliper up. You may have to order the kit from your local auto place or your favorite Corvette catalog.
Often, the piston won't come out of the caliper half without a fight. The trick is to use air pressure from a compressor to blow it out. CAUTION HERE! Use low pressure because anything too high and the piston will come out like a shotgun slug. Put a rag over the piston and hold it on with your free hand, put your rubber nipple from the air hose gun nozzle into the bleeder and give a quick, short burst of air. Again, use very low pressure. You can always increase the pressure in small increments until it comes out. Don't ask how I know about this.
Gary
Old Jul 4, 2006 | 02:13 PM
Hammerhead Fred's Avatar
Hammerhead Fred
They can be gently pried out intact with a flat head screwdriver.
Simply pry from below the ring and work your way around.
They are cheap and easy to replaced so reusing them, while possible, is not recommended.
Old Jul 4, 2006 | 02:37 PM
Lucky68's Avatar
Lucky68
thank you, i can't get the ring from the OD even with a tiny screwdriver tip, it is too tight. I guess I will just tear the boot and possibly get the ring out from the ID if i can.
Thanks, i'll get it out somehow...
Old Jul 4, 2006 | 05:55 PM
redvetracr's Avatar
redvetracr
push the piston down, then use a medium size screwdriver under the metal lip of the boot, twist the screwdriver and it should pop....and as posted above DO NOT REUSE the boot or the lip seal.
...redvetracr
Old Jul 4, 2006 | 07:10 PM
cmac72's Avatar
cmac72
For under $10 you can pick up a seal puller from Autozone - works much easier than a screwdriver and can be used to pull other seals around the car. I agree - replace all the rubber parts inside once you pull the pistons.
Old Jul 4, 2006 | 07:31 PM
JBB's Avatar
JBB
Gary
I would just add that a piece of 2x4, inserted in the caliper (in place of the brake pads) catches the piston(s) nicely when they fly out.
Old Jul 4, 2006 | 08:28 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Be careful when pulling the seal, you don't want to go too deep and gouge the piston bore.
To caliper piston removal
