Rear Suspension
Old Jul 4, 2006 | 04:04 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Default Rear Suspension
I need to raise the ride height of my 81 back up. I have a very large stereo system wieghing about 200lbs in the cargo area. How do I do this?
Old Jul 4, 2006 | 04:36 PM
revel_inmy_loss's Avatar
revel_inmy_loss
tighten the bolts on both sides of the rear spring and then.... your done!
just make sure you tighten them even amounts (count your turns)
Old Jul 4, 2006 | 09:45 PM
Tim_Ko's Avatar
Tim_Ko
It may not be easy to turn those bolts because of rust/scale/dirt on the threads. Clean the threads off with a wire brush, spray it with WD40, and use the technique - tighten a half-turn, loosen 1/4 turn ... tighten a half-turn, loosen a 1/4 turn. When using the wire brush, ... use a lot of elbow grease and it will make the wrenching a lot easier.
Old Jul 4, 2006 | 10:42 PM
HO-alts-Rick
I only have one rear spring????I am confused, Anybody have pics of what bolt I need to tighten? Is it like torshion bar on a chrysler?
Old Jul 4, 2006 | 10:47 PM
birdsmith's Avatar
birdsmith
That spring has a long bolt at either end which anchors the end of each trailing arm to it. By tightening those bolts you are pulling the back of the car UP. If you run out of threads you can get shorter bolts; just make sure they're Grade 8 minimum.
Old Jul 5, 2006 | 10:09 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
At this point, before turning any wrenches, you should get a service manual and flip through it to at least gain a passing familiarity with how your car is put together...
Old Jul 5, 2006 | 10:22 AM
mensch53's Avatar
mensch53
Read and understand before you even touch a wrench. I have been baffled by many a project before I got on here and asked the right questions. Search through the archives here for pictures of some nicely put together rear setups and that will help a lot in understanding what people are talking about. Look at the long bolt a few inches off the ground just inside each rear tire and it will start to make sense.
Old Jul 5, 2006 | 04:25 PM
Bee Jay's Avatar
Bee Jay
200lbs sound system? This we gotta see. Can you post pictures?
Old Jul 5, 2006 | 05:15 PM
Meh's Avatar
Meh
My friend had one of those. Finally divorced that biatch.
Old Jul 5, 2006 | 05:26 PM
Bee Jay's Avatar
Bee Jay
Dude, that was funny.
Old Jul 5, 2006 | 05:27 PM
Twin_Turbo's Avatar
Twin_Turbo
To Rear Suspension
