Hydroboost, yet another question
Old Jul 4, 2006 | 07:36 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Hydroboost, yet another question
How the heck do ya get that big not off that thing? Its a 4 sided 1 7/8 with rounded corners and its down in the recess in the mounting plate.
I don't have anything to get on it with
TIA
Old Jul 4, 2006 | 08:50 PM
mrvette's Avatar
mrvette
TIA
hehe....I took my CP711 air chisel with a dull blade on it, and tapped it off from several differant spots....
I cheat....worked fine....I put it back on same way, and used locktite red...not as tight....still stable 4 months later or so...
GENE
BerniesVette's Avatar
BerniesVette
Sixfooter,
Even though 25 year old brakes have to be as good as those of today, I am still going to add hydroboost too. I should receive one from yellow73sb this week and will be doing the same things you are going thru now. I hope you get the answer to this and if not, as soon as I get mine, we can figure it out together! Good luck!
Bernie
Old Jul 4, 2006 | 09:32 PM
SIXFOOTER's Avatar
SIXFOOTER
Good deal Bernie, thanks
Norval, Houston, Yellow, you other guys, how did you do this?
Old Jul 4, 2006 | 10:04 PM
Jclgodale3's Avatar
Jclgodale3
I used a big set of channel locks...no problem
Old Jul 9, 2006 | 10:24 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
well i was working on my brake system today and took my brake booster off and it fell apart so i am looking at either ordering a new brake booster from Kragen autoparts or maybe going to a hydroboost setup. need a little info on the hydroboost setup though. i am thinking that i might just stick with the original brake booster now that i have awsome vacume now at idle with my new EFI setup im getting 11" at idle now instead of the 3-5 inches that i had before.
To Hydroboost, yet another question
