Help me decide which headers to use
This ios a 69 L46 motor rebuilt with 9~9.5:1 about 10,000 miles ago and performance intake and some other goodies. Currently has block hugger headers with a 2.5" straight pipe older somewhat rusty through flowmasters.
Header #1
Hedman #68300
1 5/8" Primary Tubes
16 guage
1/4" flange
Benefits I see is that the tubes are thicker 16 guague and are 1 5/8" so I should not loose any torque, but they are not equal length and have a nasty 90* bend in them.
Header #2
Hooker Super Comp #2134
1 3/4" Primary Tubes
18 guage
5/16" flange
Benefits I see are the tubes are very close to equal length (I measured with filling them up with water and then comparing the difference in water volume needed) and have more smooth bends, but the tubes have thinner walls and are larger 1 3/4".
Also going with the header install at the same time will be a complete Magnaflow muffler & x-pipe system all 2.5" mandrell bent.
I am not worried so much about low end power below say 2,500 rpms because I have maximized my gearing to compensate as the car now has a 6 speed ROD with a 3.70 rearend with a torque multiplication ratio of 11.137 for first gear. I am more concerned about hp/ft lbs. around the 2,500 to 6,000rpm range.
I am trying to weigh the benefits I guess of smaller tubes with 90* bend vs. larger tubes with a more smooth bend.
Which do you all think I should go with based on my dyno chart and where I want to maximize my HP in my rpm range?
I am looking at exhausts at the moment and nearly everyone has advised me to go with the Hookers. They seem to be one of the top after market manufacturers.
Oh, and I personally went with the best deal I could find on headers. Summit long tubes. They're probably made by either hooker or hedman but they're sold under the summit name for $75 now.
Anyway...The Hedmans are chrome or ceramic coated (look really nice and shinny) and the Hooker are just plain normal painted if this helps at all. I am leaning more towards the Hedmans right now since I am not putting down that much HP, but I was still surprised to see 260 ft lbs so I am somewhat hesitant to go with the smaller diameter 1 5/8" in fears that I will kill the 260 ft lbs to even a lesser number.
Like I said, my L81 with a mild cam, long tubes, sidepipes, HEI, and normal q-jet is putting down more power than that.
I think Id be considering matching a new "header & muffler" setup to the new 400hp engine youll be getting soon. Looks like the engine you have in now is low power but valuable because its number matching , so just leave it intact and pull your present exhaust, store it, and choose the new system to go with your future 400hp engine, That way you wont have to rebuy the exhaust, you wont be seeing any significant difference on your present engine anyway. The 1 5/8" primaries is plenty good for your future 400 HP+ motor too.
Also..
You mentioned your not concerned much about low end torque with your new gearing, Let me point out that your overdrive gear will be pretty dead if theres no low torque available when you shift to 6th. Im not saying thats a problem, in fact its not. All it means is if you dont have low end torque your car will excelerate "Real slowly" in 6th till you get up to maybe 80+ then the overdrive gear will be under power again and will pull hard to maybe 130-140 or wherever 6000rpms is without over reving. This was the case with my .62 overdrive gear. Doesnt make much difference now, but its good to know, makes choosing what cam and what intake port size for the new heads a little easier in the future. Just thought Id mention it, Im having the same considerations ever since installing the ROD.
Tom
Cheers....
Hedman makes a good cheap header but hookers are better quality.
This does not apply to the hedman elite.
http://store.summitracing.com/partde...5&autoview=sku
The other pair of headers headers that I had to install were a used set of Hooker Super Comps #2134 being only painted (not ceramic coated) and have the thinner 18 guage pipes. So now that I am satisfied with my current setup I will be selling theh Hooker here shortly after I take a few pics of them.
