Best Location for Oil Temp Sensor
Old Jul 6, 2006 | 05:18 PM
flynhi's Avatar
flynhi
Default Best Location for Oil Temp Sensor
Please post your opinion as to the best place for sensor location for an accurate oil temp reading.
I currently have the sensor (which was checked for accuracy before installation) installed on a t fitting on the block near the oil filter location. My gauge reads about 75 degress higher than indicated by an IR gun reading temp of oil lines to my remote oil filter or two pass oil cooler.
The t fitting is a dead end contact. In other words, oil does not flow through it, it is stagnant in the fitting. Does this matter?
Should I be reading at the block or oil pan or in the line to the filter/cooler or ?
Old Jul 6, 2006 | 05:37 PM
norvalwilhelm's Avatar
norvalwilhelm
I had the pan off and welded a bung directly into the side of the pan. The sensor is always submersed in the oil. Mine moves quit a bit. Stop in traffic and you will see it climb but within a few miles on the open road it quickly drops back down.
Old Jul 6, 2006 | 09:04 PM
markdtn's Avatar
markdtn
82 and C4 have it in the port in the side of the block just above the filter.
Old Jul 6, 2006 | 09:36 PM
flynhi's Avatar
flynhi
My 383 tpi is based on a 90 block. The t fitting I described above is screwed into the port adjacent to the OE oil filter location.
Old Jul 7, 2006 | 07:38 AM
markdtn's Avatar
markdtn
Why do you need a Tee there? You can get pressure on the port on top of the block back by the distributor.
Old Jul 7, 2006 | 11:47 AM
flynhi's Avatar
flynhi
Marktdn,
I have a tpi with an HEI distributor. It's awfully crowded back there. So I moved the oil pressure sensor down below.
Old Jul 7, 2006 | 12:45 PM
zwede's Avatar
zwede
I would think Norval's solution would be the most accurate.
Old Jul 7, 2006 | 05:33 PM
LannyL81's Avatar
LannyL81
Just wondering...how do you get the plug out of the block in order to install the temp sensor? Is this one that needs to be heated to get out? Or should I try taking it out when the engine is hot?
To Best Location for Oil Temp Sensor
