Sagging rear end
Old Jul 7, 2006 | 02:57 PM
MichaelG's Avatar
MichaelG
Default Sagging rear end
Just bought a 69 vette. I just noticed that the driver side of the rear end is sagging. Looks like one inch at the wheel well. Can the rear supension height be adjusted? I tried searching this but cam up with nothing.
Any thoughts?
MG
Old Jul 7, 2006 | 03:29 PM
GruntyPants's Avatar
GruntyPants
Take a look at your rear spring bolts where the trailing arms attach, you can adjust the ride height by adjusting the nut on the bottom. Have a look at the bushings as well, you may just have one side that is completely rotted/destroyed/or missing.
Old Jul 7, 2006 | 03:59 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Jul 8, 2006 | 05:54 PM
MichaelG's Avatar
MichaelG
Thanks guys. I think one of the bushings is done.
Old Jul 8, 2006 | 05:58 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Here is a short...similar post from the C3 "general forum" on the same.
http://forums.corvetteforum.com/show....php?t=1439429
Old Jul 8, 2006 | 06:06 PM
...Roger...'s Avatar
...Roger...
Any thoughts?
MG
Because of the rear spring mount being in the center the rear end leaning is usually caused by the front end having a problem.Release one side of your front sway bar and see if it straightens up-if it does the bar is bent.These cars get hit in the front alot and it really effects the rear.
Old Jul 8, 2006 | 07:02 PM
77vettejeff's Avatar
77vettejeff
I had a similar problem. Mine was body mounts. Check the #3 and #4 mounts
To Sagging rear end
