Demon Carbs quality control
sure enough their was aluminum shavings in the main body blocking flow and in the metering blocks. The carb is going back because I felt paying $500. plus I shouldn't have to take apart a new carb, who knows if I got all of the aluminum out, so much for the "quality control" tags on the carb..:
I know one can slip through the cracks but I could of done some real damage to my engine. I have owned several of these carbs and it seems I always find some "quality control" problem with their carbs out of the box. I called the tech today and told him what I found, it wasn't his fault but he was glad I called and notified him that Demon bases their success on their reputation, they make a good product, just make sure to check it out carefully before you install and fire it up...jmoSorry to hear that you had these problems.
We’ve found some carburetors (less than 1% of what we manufacture) with some debris in them, which is unacceptable. The goal is to have absolutely none, and to build the best product possible.
Since the majority of our products are made from billet components there is a higher chance of these types of issues than with cast components.
In the past a carburetor could have had trapped debris, and pass a flow test, but while getting bounced around during shipment the debris could become dislodged.
We have instituted the following changes to prevent these problems:
1) A vacuum system has been installed in all areas where drilling or machining is done to remove any debris from the parts.
2) A timed lock system has been installed on the pressure washer for the metering blocks to ensure they are flushed for the proper time.
3) Metering Blocks, and Main Bodies go through ultra sonic cleaning before final assembly.
4) Gaskets come from a sealed area to prevent debris from getting on the gaskets before the carburetors are assembled.
5) As always all carburetors are flow tested to proper specifications.
We appreciate the support, and feedback from our customers, and as always use this information to continually improve the quality, of our products, and services.
Technical Support,
Barry Grant, Inc.
Can I say the're better than a holley or Q-Jet? no not really, but I find them well built, perform brilliantly and they look real cool on my engine
I have had it apart many times and have found nothing inside that wasn't supposed to be there
EVERYONE has manufacturing issues - making a gajillion of anything is no simple task. Just because there is nobody on the forum complaining about machining debris does not mean Holley's do not have other issues (see the current thread with the plating coming off the bowl). I took apart an edlebrock carb and found flashing blocking one of the ports, among other things.
Some holley's will run better than others and some demon's will run better than others. It would be nice if they all ran perfect, but what part ever went into a corvette perfectly in every instance? NONE.
If you have to choose between a carb with design and manufacturing qualiy issues or one with easily addressed manufacturing quality issues (and that seems to be the choices), which should you choose?
Edlebrocks are not performance carbs (despite the 'chrome' plating), holley's are extremely subject to the casting quality and have other design weaknesses, and demon's have machining debris. I can clean machining debris, I can't solve carb design problems or casting issues, and I would never install a carb without an initial teardown anyways - it only takes an hour and if you don't do it and it drops a nut in the intake when you fire it up you are going to wish you did, even if you can eventually get compensation for your pain and suffering.
Saying this or that sucks and you would never use it because somebody once complained will eventually have you sitting in a dark closet afraid of everything! A little common sense will get you much much futher than anything you read on the web, including this response.
btw...I just fired my car up after 6 months and it started as soon as the bowls filled. no issues with my Mighty Demon.
Others are a bit more particular. The Demon carburetors are fairly expensive and while the customer should expect it to require a bit of tuning to work with their particular application the customer should not have to spend countless hours trying to get the Demon to function reasonably well. It sounds like most Demon carbs work out pretty well but if you are the unlucky customer who purchases a Demon with abnormal issues, it’s a bit tough to maintain your “freaking perspective”. Know what I mean?
I haven’t purchased a Demon. I’m still hung up on the old Q-Jets but I have a brand new Demon, complete with issues, on the shelf in my shop. It belongs on top of a friend’s stroked Cleveland. Eventually, we will get it worked out but WAYYYY too much time was spent trying to dial it in. Other projects took precedence so he removed the Demon and tossed an Edelbrock carb on it and while not the performance carb that his engine deserves, it runs perfectly.
While I don’t claim to be a Demon carb tuning expert, I’m certainly not a mechanical moron either. We will get the Demon worked out when the time comes. Again, for the cost, it just shouldn’t be that challenging.
Congratulations! That is exactly the way it should be. Everyone wants to have that same experience!
But for people to say I would go with this because someone complained about that is ridicorous! The Demon design is superior. I believe in superior designs. That's why I bought a vette instead of a camaro.
Technical Support,
Barry Grant, Inc.
I went back to my original speed demon that I know doesnt have issues. Again, the carbs are quality products, maybe just got a few bad ones here...however I have heard this before about BG's quality control issues...again, just what I found
71roadster- "Freaking perspective" good choice in words, I always go through a carb before I install one
screws, settings, etc. that's how I found other Q/C issues before with the BG carbs....loose screws, sight glass on bowls leaking, small things one checks Before you install it...
TJ
TJ
I've worked in manufacturing all my life and can understand how things like this can happen. From the continual comments about the metal shavings and quality issues it makes you wonder if the corrective actions they've taken are having an effect on the problem. Unless distributers have a ton on inventory they're working through.
I can agree to some extent with both sides of the issue but I really have a hard time agreeing that after spending $500 or more for something I should be the final inspector and be required to take it apart and inspect for poor workmanship. Give me a break!
Couldn't agree more. How hard is it/how much time deos it take to take a speed demon apart and check everything out. I've got a brand new speed demon sitting on my motor right now and after reading this I wonder if I should pull it off and check it out.
Yet another thing goes on the to-do list...
TJ
As far as tuning goes the LM-1 Innovate systems are really good. They can make almost anyone a “Tuner”. The only downside you have with them is that each engine may want a slightly different tune-up, and more importantly each hole can be a little different. I’m currently using 8 LC-1 setups so I can accurately measure each hole as I tune.
Technical Support,
Barry Grant, Inc.
I don't know diddly about carbs, but just bought a Speed Demon 750 w/vacuum secondaries. Can you please guide me on what to take apart and look so that I can avoid the problems listed here. In other words where I should look for debris. Since I don't know much, please be specific as to what the part looks like that I am to remove and the proper way to re install it. Will I need to buy any gaskets, o-rings, etc. to put it back together? Please advise as I'm about to drop my new motor in and would like to make sure my Demon carb is all ready to go. As you can imagine with a new motor I'll have plenty of things to be checking on and adjusting, so hopefully I can go ahead and get that carb squared away in advance. BTW, any picture that you could attach to help explain would be most helpful. Thanks a million in advance!
I won't ever be buying one.
