Sparkplug wires.
Old Jul 8, 2006 | 12:24 AM
JustForFun's Avatar
JustForFun
Default Sparkplug wires.
what wires are you guys running? application. Im looking for set of wires i can run from dist. down and over valve cover and onto plugs.
seems every set i find has wires that are WAY to long and couple little short. Im sure theres an application that would be a closer wire to what i need for an 81
Old Jul 8, 2006 | 12:35 AM
Jclgodale3's Avatar
Jclgodale3
I used a set of Taylor SpiroCore Universal application wires. You cut them to length and apply the distributor ends for a perfect fit, however you want them to run...
Old Jul 8, 2006 | 12:40 AM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
same ones i use .
Old Jul 8, 2006 | 12:50 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
If you get any cut to fit set and install your own boots, you will get the "right" fit no matter how you want to route your wires.
Here's a set of Accels I put on my 75 last year before trimming/boot installation and again after everything was in place. Not the most fancy, but they work.
Good Luck!
Old Jul 8, 2006 | 12:51 AM
BLUSHRK's Avatar
BLUSHRK
me too.
Old Jul 8, 2006 | 03:42 AM
Kalway's Avatar
Kalway
The lifetime warranty ones that I got at NAPA. Belden Max they're called and they're pre-cut and everything for ya.
Old Jul 8, 2006 | 07:20 AM
TopGunn's Avatar
TopGunn
Taylor 8mm here.
Old Jul 8, 2006 | 07:40 AM
harrin's Avatar
harrin
Taylor Thunder-Volt 8.2mm
Old Jul 8, 2006 | 09:02 AM
1BAD80's Avatar
1BAD80
Crane Firewire, 25 ohm ft Universal application wires.
Old Jul 8, 2006 | 09:12 AM
JoeRags's Avatar
JoeRags
8.5mm MSD superconductors... cut to fit.
I bit the bullet and bought the $50 MSD crimp/cut tool... works wonders
Old Jul 8, 2006 | 02:49 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this is from MSD 8.5 made to go over the valve covers...moroso makes a really nice set with a wire loom
[IMG][/IMG]
i replaced those spark plug wire seperators withe the ones like inthe first photo
[IMG][/IMG]
Old Jul 8, 2006 | 10:46 PM
rweasterly's Avatar
rweasterly
msd 8.5
Old Jul 8, 2006 | 11:10 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by rweasterly
msd 8.5
Me too.
Old Jul 10, 2006 | 10:06 AM
Hop's-vette's Avatar
Hop's-vette
I just got these MSD wires too, but haven't had time to put them on yet.
Old Jul 10, 2006 | 10:27 AM
rosslato's Avatar
rosslato
thats also what i used
Old Jul 10, 2006 | 11:14 AM
crazywelder's Avatar
crazywelder
MSD 8.5 cut to length. Now they are available in black.
Old Jul 10, 2006 | 11:36 AM
Z-man's Avatar
Z-man
MSD 8.5 - under the headers as God intended...
Old Jul 10, 2006 | 11:43 AM
luerja's Avatar
luerja
Best Bang for your buck is with Taylor 8mm wires, get the ones you have to cut to lenght and take your time.
To Sparkplug wires.
