Vette is alive...but
I dumped fluid into my converter prior to installing it. I had my pan off as well. I believe it took about about 6 more quarts to get it to the proper level after firing up the engine. I assume the poster bolted the converter to the flex plate.
i had the same thing happen this past week when i was installing my engine. i went to put the engine in but it wouldnt get close enough to the transmission to bolt the two together so i pulled it back out and sure enough i didnt have to converter put on all the way so i just spun it and pushed till it slipped on all the way. after i got it on all the way the engine bolted up just fine. i cant see how you could have the engine bolted up without having the converter on all the way like it is suppose to be
I dumped fluid into my converter prior to installing it. I had my pan off as well. I believe it took about about 6 more quarts to get it to the proper level after firing up the engine. I assume the poster bolted the converter to the flex plate.[/QUOTE That is my take on it too. I engaged the converter turned it and it engaged again and went all the way in the trans. I had to pull the converter back towards the flexplate to bolt it up. So I was like yep it's fully engaged. However, the converter is the only thing that changed with the trans since I didn't pull it. I unbolted the converter from the plate yesterday afternoon and tried to get it to engage further with no luck. Pulled it back to the plate fired it up and nothing. It's got plenty of fluid and I actually got to the point of overfill hoping that was the problem. I feel fairly certain at this point I fouled up engaging it. Hey though, my new gmpp 350/330 motor runs great!! Too bad it won't go down the road under its own power!!
I really hope you didn't shear off the ears from the pump. I hate to say it, but it looks like the next step is going to be removing the trans all together.
BTW - I have an "extra" toque converter if you need one. A buddy of mine gave it to me several weeks ago. He said it worked fine!
Here's some more good info:
INSTALLATION OF A TORQUE CONVERTER
1. Always lubricate the converter hub and pilot. It is recommended to use a new drive plate. It is imperative to replace the drive plate if there is any evidence of bending, cracking, or other imperfection.
2. Fit the converter to the engine. Look at the fit, checking for excessive wear on the crankshaft area. Remove. Fill the converter with as much transmission fluid as possible.
3. Assemble the converter onto the transmission. Rotate the converter. On most applications you will feel it drop into place. Continue to rotate. A second drop will occur. You must be certain that the converter has been turned more than one full revolution to insure correct positioning on the stator/input/turbine shaft.
4. Install the bolts that attach the transmission assembly onto the engine. Then tighten the converter drive plate bolts. (Improper technique would allow the drive plate bolt tightening to draw the converter into place. This often mounts the converter ears on top of the pump gears, causing premature failure.) Install the transmission and rotate the converter to ensure proper alignment.
5. Some applications will not allow the above method of installation. In these instances, assemble the converter onto the transmission. Rotate the converter until it has dropped into place. When you have good tang engagement, mark the converter at the 12 o'clock position. Remove the converter without rotating. Mount the converter to the engine flywheel. Before installing the transmission, position the converter so that the mark is once again showing at 12 o'clock. Now bolt the transmission to the engine. This is not a foolproof method. It takes careful handling to reduce the chances of improper engagement.
that was my first thought. if it was not in place when the bellhousing was tightened it will damage the front pump.
When I swapped my engine and installed a higher converter I did not have the converter engaged and there was no possible way the two (engine to tranny) would meet. I also agree on drinking after **** like that happens, been there and did alot of that during my resto.
