I need your advice.
Old Sep 2, 2001 | 12:05 AM
John Dirks's Avatar
John Dirks
Default I need your advice.
I installed a longer rear spring bolt on the right rear, to try and get the body to sit level. The body now is pretty close to level, but now the right side of my leaf is 1.25" closer to the ground than the left. Is this wrong? Should the leaf be arched equal on both sides of the diff ? Please give me some feed back.
Old Sep 2, 2001 | 12:19 AM
Tom454's Avatar
Tom454
Default Re: I need your advice. (John Dirks)
You should not have to use different length bolts. There must be something else causing the problem.. personally, I would identify the actual cause and make the proper repair.
Old Sep 2, 2001 | 12:29 AM
John Dirks's Avatar
John Dirks
The right rear fender lip was measuring 1" higher off the ground than the left.
Someone told me to put in a longer spring bolt to adjust that, but now the spring looks funny arched unequally.
Any ideas?
Old Sep 2, 2001 | 12:35 AM
Tom454's Avatar
Tom454
See the post below... rotted, missing, rusted body mounts...
http://forums.corvetteforum.com/zerothread?id=143909
[Modified by Tom454, 10:38 PM 9/1/2001]
To I need your advice.
