in the front Left side there was a ground attached to the rad core holder does anybody know what the ground is for also i read in one of the threads that there should be a ground hooked up to the bell housing. I can't find anything in that area not even loose wires. If anybody can help please, Mark
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yes there is a black gorund wire that goes to your radiator....look inside the left front fender area just in front of the radiator and you should see the electrical connection that hooks up the front light harness. i think it comes from this union.....and there is a black ground that comes from the wiring harness that goes to the starter and the black wire in it is the wiper ground that mounts to a transmision bell housing bolt
