Odometer gear
Old Jul 10, 2006 | 09:51 PM
Tom68's Avatar
Tom68
Default Odometer gear
My 68 odometer is not working the speedo works great but it won't rack miles. Where can I get a gear for this ?
Tom
Old Jul 10, 2006 | 10:37 PM
lowbuck72's Avatar
lowbuck72
I got my parts from a junk speedo on ebay for $10. Note that the gear in question is peened on, and you will most likely need to use the housing from the donor speedo. The swapping of parts is easy. The hardest part is removing the speedo needle without breaking it off.
Old Jul 11, 2006 | 01:13 AM
Bob Onit's Avatar
Bob Onit
After you push it in to re set it to zero... turn it the other way and set it to 1 10th mile ....pull it back out and and see if it clocks...Ill bet it will work
Both of my 73's had this problem
To Odometer gear
