Backfiring Problem...any suggestions?
Old Jul 11, 2006 | 01:38 AM
kaymonster's Avatar
kaymonster
Default Backfiring Problem...any suggestions?
I was wondering if anyone could help me out. I'm not the greatest mechanic and cant seem to fix this. I get backfire through the carburetor, i've just about have no power on the road (especcially up hills) and the engine diesels real bad when i try to shut it off. so far i've changed the spark plugs, checked the timing, all plug wires are wired correctly, the distributor, wires, and ignition coil are new. is it a carb tuning or something??? I'm all ears if anyones got a suggestion.
Old Jul 11, 2006 | 03:44 AM
Graemeinvette's Avatar
Graemeinvette
You say you have checked your timing but thats what it sounds like. Read the Sticky on timing at the top of this section for the correct way to do this.
G
Old Jul 11, 2006 | 05:33 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Sounds like your distributor is 180 degrees out
Old Jul 11, 2006 | 06:47 AM
BigBlockk's Avatar
BigBlockk
Backfiring through the carburetor is a lean condition. Check to see if the accelerator pump is supplying fuel. No power on grades could also be a lean condition. The power piston could be stuck, float level could be low, could have trash in jets. The run on could be timing related. Retarded timing contributes to run on.
BigBlockk
Later.....
Old Jul 11, 2006 | 08:04 AM
Razorhorn's Avatar
Razorhorn
I had a similar problem with my 75. I didn't have the dieseling problem, but I was getting a lot of back-firing out of the carb. I simply pulled the carb and cleaned it as a first step, re-installed it, and it fixed the problem. Most likely I had a problem with the jets, but I went ahead and cleaned everything up. Down here in Texas, we are starting to see a lot of 10% Ethanol fuel mixtures. I might be wrong, but I am suspicious that these new mixtures are dredging up a bunch of garbage from my old fuel tank.
Old Jul 11, 2006 | 01:54 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
If the distributor were 180 degrees off, the engine wouldn't run.
Backfiring through the carb is likely a timing issue. If you've checked your timing and it appears to be set to specs, you may have a harmanic balancer with a spun outer ring giving you bad readings. Also, I'm assuming your plug wire are properly routed,..right?
For now, retard the initial timing until you eliminate the backfiring problem (turn the distributor clockwise).
The dieseling is likely caused by the throttle blades being open too much at idle. But if you retard your inital timing you'll have to open the TB's further to maintain your idle speed which will aggravate the dieseling prob.
So, I'd switch to manifold (full-time) vacuum (if not already) which will mean you'll need less of a throttle blade opening at idle. If this is q-jet carb, use the port on the passenger's side of the carb.
Also, if this is an old, tired engine with poor compression, your throttle blades will be need to open more and dieseling will be hard to eliminate,..or if you have a snotty cam that idles at a higher idle speed, sometimes it's hard to eliminate dieseling.
Good luck!
Old Jul 11, 2006 | 02:48 PM
68coupe's Avatar
68coupe
what is your timing set to?
Joe
Old Jul 11, 2006 | 05:32 PM
FKING1's Avatar
FKING1
Double check the plug wires and check #1 at TDC and recheck the wire order. I had a similar problem with my 70 L46 and it turned ot to be 2 plug wires switched. Worth a double check.
Fred
Old Jul 12, 2006 | 01:07 AM
kaymonster's Avatar
kaymonster
Joe
It is 8 degrees.
Old Jul 12, 2006 | 01:10 AM
kaymonster's Avatar
kaymonster
Good luck!
do you mean dissconnect the hose at the distributor and connect to the manifold?
Old Jul 12, 2006 | 01:12 AM
kaymonster's Avatar
kaymonster
The fuel pump is working fine and the wires are correctly (verified twice) installed. The carb backfires bad, often throwing flames up. i can only get up to about 40 mph on a flat road...and it takes a while
Old Jul 12, 2006 | 01:54 AM
tfi racing's Avatar
tfi racing
Pull off your rocker covers and look for an obvious pushrod or rocker arm problem,or even worse you may have lost a cam lobe or two.A compression and or leakdown test might be a good idea to help diagnose your problem.
Old Jul 12, 2006 | 03:32 AM
Graemeinvette
It is 8 degrees.
That sounds low, should be around 12 degrees. Make sure the tube for your vacuum advance is disconnected at the carb and the nozzle you removed it from is blocked off before you re-check your timing and be sure to re-connect it afterwards. But before you do that be sure and check your points gap.
Old Jul 12, 2006 | 10:28 AM
68coupe's Avatar
68coupe
It is 8 degrees.
Wait a second, I do not think you have the timing correct.
Do you have an adjustable timing light?
Pull the vacuum advance off the carb.
Plug the vacuum port on the carb temporarily.
Check the timing at full advance.
It should be 36.
Thanks,
Joe
Old Jul 12, 2006 | 09:08 PM
wnjlt1's Avatar
wnjlt1
may i ask how was the car running before you replaced all the parts? how does she idle, shakes, misfires? are running points or electronic / hei? have you tried to advance the timing to see what she does?
Old Jul 14, 2006 | 10:10 AM
kaymonster's Avatar
kaymonster
yes i have. It ran fine..... it had been garaged for 15 years when I aquired the car through a death in the family. it looked perfect but i had a mechainc friend do a full inspection and had things fixed/replaced (gas tank, plugs, distributor, cooling system flush, etc, etc,) so i could fire it up. it ran fine for about 300 miles. one day i tried to start it and it just had all of these symptoms. i expected problems, but i cant seem to find the source of this one
kaymonster's Avatar
kaymonster
To Backfiring Problem...any suggestions?
kaymonster's Avatar
kaymonster
Old Jul 14, 2006 | 10:12 AM
Boofers's Avatar
Boofers
my money is on vacuum leak
Old Jul 14, 2006 | 10:43 PM
77327's Avatar
77327
You can check the ignition timing by finding top dead center on the #1 cylinder, and checking the position of the distributor rotor. It should point in the direction of the #1 cylinder. To verify this, check the repair manual for your corvette year and engine. The firing order will be in there, so you verify what position the distributor rotor should be pointing when #1 cylinder is in top dead center.
