Rear Clunk
Old Jul 12, 2006 | 10:20 AM
corvette_maniac's Avatar
corvette_maniac
Default Rear Clunk
I just bought this `75 and there is a clunk that is heard and felt when creeping forward or backwards at a few MPH. I initially thought it to be a u-joint, but this morning I checked them out and visually they look ok. I greased the half shaft's u-joints. I also put it in drive while it was on jack stands and heard nothing - probably because there was little load on the drive train. I noticed that it doesn't do it in neutral while rolling either.....again, little load on the rear. Does this sound like a u-joint or do I have other major problems looming such as rear end?
Old Jul 12, 2006 | 11:25 AM
MartyW's Avatar
MartyW
Try the easiest thing first. I see threads like this all the time and what is always suggested is a flush and refill of the rear differential and especially important to add a bottle of the GM Differential addative which is like $7. I had the same type of sounds comming from the rear of my 76 under the same conditions and I just flushed and refilled mine the other night and added a bottle and MAN does it make a difference. My rear end noise went away almost completely. I have seen others here spend thousands trying to track down a rear end sound like yours and some never try the simpliest solution. Try the GM addative....they will have it at your local GM dealership.
Old Jul 12, 2006 | 01:20 PM
mensch53's Avatar
mensch53
I had a similar problem and this took care of it.
Old Jul 12, 2006 | 01:55 PM
corvette_maniac
Cool....thanks a lot guys. I can tell that I am going to love this forum as much as my car!....well.....
Old Jul 13, 2006 | 01:47 PM
Mark PittPayne's Avatar
Mark PittPayne
Follow that advice and you should be fixed up. Just one word of advice. Don't put your vehicle in gear while on jackstands or you will be replacing Ujoints, among other things. Real bad for the car.
Old Jul 13, 2006 | 03:47 PM
68sbShark's Avatar
68sbShark
Not a good idea to rotate the rear tires (ie. put it in drive and let the wheels turn) while the car is in the air, unless the suspension is loaded. The severe angle the shafts are at when the susp is hanging really stresses the joints and binds pretty bad.
with replacing the fluid. Also, check the front diff mount. They tend to get pretty flat and make some noise.
~Rich
Old Jul 13, 2006 | 05:18 PM
Chev-Hell's Avatar
Chev-Hell
my car is doing the same feels like someone kicking the floor under braking and when taking off
Old Jul 13, 2006 | 08:42 PM
ManFromEagle's Avatar
ManFromEagle
Have you guys thought about the front differantial carrier bushings.
They rot out and need to be replaced. That was the clunk on my car.
Old Jul 13, 2006 | 09:12 PM
driver68's Avatar
driver68
yup, same for me, had a similar clunk at very slow speeds, and it was the lower differential bushing.
Old Jul 13, 2006 | 09:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
my money is onthe front differential bushing....and use locktite when putting it back together
Old Jul 14, 2006 | 12:54 PM
revel_inmy_loss's Avatar
revel_inmy_loss
I took my car for its first test drive last night, and snapped the front diff mount off the frame... damn rust
Old Jul 14, 2006 | 03:35 PM
savage118's Avatar
savage118
I had a knock that i thought was the front diff bushing, turned out to be loose passenger door striker, hinge springs. For months I was sure that was were it was coming from (sound). Till a passenger said she could feel the door moving with the bumping noise. She held the door down, noise stoped. I could have swore it was underneath car.
Old Jul 14, 2006 | 05:58 PM
corvette_maniac
Tomorrow I am planning on changing the diff fluid and add the additive. Me being a Firebird guy and being able to get on all 12 bolts with ease makes me wonder what I'm getting into. Is it very straight forward or will I have to remove a lot to take the cover off of the differential?
Old Jul 14, 2006 | 06:10 PM
DSchaefe's Avatar
DSchaefe
There is a plug on the passenger side, you'll need a vacuum pump to suck the old stuff out. To remove the differential cover requires lots more work, removing the spare tire tub, the leaf spring, the crossmember... You'll want to eyeball the spring mount on the diff cover, it is common for these to crack and cause a clunk when moving from standstill.
Old Jul 17, 2006 | 09:27 PM
corvette_maniac
Well I drained and replaced the diff fluid (adding the GM additive first). I did some figure 8s and drove it 10 miles or so and it is still clunking at low speeds. ...so it's time to look at those bushings.
On a lighter note, I stopped all of my power steering leaks by rebuilding the control valve yesterday. I woke up this morning to find a puddle under the car! Turns out it was a combination of the control valve and power steering return hose. I just went ahead and replaced all hoses and now I'm pretty sure I'm leak free.
To Rear Clunk
