vapor lock problems on a 68
Also be sure it is actullay vapor lock, and not a clogged fuel line or fouled fuel pump....
I just went through this whole deal:lol
Running great now
But first...how have you confirmed its vapor lock? Are you sure your carb isnt leaking fuel into the manifold after you shut it down causing it to flood? Many q-jets have been know to do that.
- Try to buy gas without ethanol if you can find it.
- Also, 1 quart or so of diesel per 10 gallons will prevent vapor lock.
how old is that rubber line?
give classic tube a call, and put the ss hard lines in
looks better too
PS dont mind the rest of the mess, Im a work in progress
been doing more driving then wrenching
This is from the gas in the line between the pump and carb getting hot, but not hot enough to vaporize because it is still pressurized between the pump and needle seat. But when you drop the fuel level in the bowl quickly by hard acceleration, the float drops fast and far. The hot fuel rushing into the vented bowl is suddenly de-pressurized and flashes into vapor, like steam blasting from a pipe filled with hot water when you slam the valve open. This blasts pressurized vapor into the float bowl, blowing the liquid fuel away from the jets. Within a few seconds it has stabilized, and all is OK again. The only way around this, if the insulation doesn't help, is to let the engine run a few moments to let fuel level drop slowly and open the needle valve just a bit so the hot fuel in the line can enter the bowl slowly and be tempered until cool gas gets into the line. Then you can floor it.
I've done most of the things above, but this one has still gotten me a couple times. Now that I know what it is, it doesn't bug me too much, except that it usually hits me when I'm trying to be
and I'm not paying attention to my car
John
P.S. Many years ago I was hauling 3 Harley 74s from So Cal back to Colorado in my 3/4 ton '59 Apache truck in August.The ol' 6-banger was running fine but started vapor locking in the mountains of Utah. I had mounted a windshield squirter unit from a Pinto on the truck, so I wrapped the fuel line with one of my bandanas and stuck the squirter hoses into it. Every so often I'd hit the switch and soak it. Worked great, no more vapor lock from Vernal to Boulder in 90* temps......
