1.6 rocker install update/question
Old Jul 12, 2006 | 10:16 PM
Oldguard 7's Avatar
Oldguard 7
Default 1.6 rocker install update/question
I installed a set of Crane 1.6 roller tip rockers(after sitting the box for over a year) in my vehicle this afternoon. The idle is now on the lopey
side. I have the idle speed set at 700rpm. Will I need to make any other adjustments? My cam if I remember is 278/288 duration (adv)
414/442 Lift (not sure about the lift as I misplaced my cam card when
I rebuilt the engine)
Old Jul 13, 2006 | 02:49 AM
stingr69's Avatar
stingr69
Rockers too tight can cause the idle to be lopey.
I would suspect a vacuum leak assuming you have the rockers adjusted right.
-Mark.
