BB 71 vette sidepipe install question.....again
Old Sep 2, 2001 | 06:15 PM
tworottiedogs's Avatar
tworottiedogs
Default BB 71 vette sidepipe install question.....again
I have the drivers side in but It seems impossible to line up. It is hitting the clutch linkage and it looks like the lower head bolts will hit the header flange. Is there a difference in hooker headers for auto and 4 spds?? Are there any known problems with hitting the head bolts?
Old Sep 2, 2001 | 06:31 PM
tworottiedogs
Default Re: BB 71 vette sidepipe install question.....again (tworottiedogs)
Call me crazy but this does not look possible. The header is hitting the steering box, the clutch linkage and the head bolts. I know it is possible because I see Vettes with the sidepipe headers. I don't see how the clutch linkage would bolt back even if the headers would bolt in. There are two pipes directly in its path.
Any clues or should I just buy some normal headers and stick with eshaust out the back??
Old Sep 2, 2001 | 07:00 PM
JCL's Avatar
JCL
TWOROTTIEDOGS. TRY AND E-MAIL EITHER GDAINA (MODERATOR ON THIS C3 FORUM)HE'S GOT A 533BB, OR CHUCK HARMON FROM CALIFORNIA ALSO A BB, OR MASSVETTE ALSO BB. ONE OF THESE GUYS HAS TO KNOW WHAT TO TELL YOU. IF YOU HAVE A HARD TIME GETTING IN TOUCH, E-MAIL ME DIRECT AND I'LL CALL THEM. JCL :cool: :chevy
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
I'm not sure with the big block, but I know that with a sbc, I had to disconnect the clutch linkage to get the headers in. How does the other side fit? :confused:
Old Sep 2, 2001 | 07:42 PM
2nspire's Avatar
2nspire
Default Re: BB 71 vette sidepipe install question.....again (mikeo)
I had to take the washers out of the four bolts on heads so header flanges would fit on. There is lots of room for me for the z bar but the a pipe on the passenger side is hitting the frame and is also making contact with the other center pipe. On the drivers side a pipe is cortacting the steering box. I will dimple the contact areas. I also had to cut on the part below door and just behind wheel wells to fit headers. But other than this, It was a pretty good fit.
This is with the 502. Keep us posted.
O yeah. I also had to change my motor mounts because the wrong ones were in there.
[Modified by 2nspire, 4:44 PM 9/2/2001]
Old Sep 2, 2001 | 08:46 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
I installed the "Hooker" headersidepipes on my Vette but, the only problem I had was; I had to trim a small portion of the bottom of the front fender and lower trim panel to get it to fit correctly :eek: I really didn't have much of a problem with the install :cool:
Old Sep 3, 2001 | 09:40 AM
2nspire's Avatar
2nspire
Default Re: BB 71 vette sidepipe install question.....again (Intimidator454)
you've got mail
To BB 71 vette sidepipe install question.....again
