more problems
Old Jul 14, 2006 | 11:21 AM
lax36goalie's Avatar
lax36goalie
7th Gear
Default more problems
ok. i was driving my '80 on a back road today and got up to about 45. when i got that fast i pressed on the gas even more, and it wouldnt accelerate. my car just started to get slower and slower because it wouldnt do anything when i pressed on the gas. when i did press on the gas it would make this klanky noise and my car would shake. and when i got out it smelled like something was burning...rubber maybe?
anybody have any ideas as to what it is?
Old Jul 14, 2006 | 11:26 AM
Bob Onit's Avatar
Bob Onit
Did you look at the temp gauge?
Was it running very hot?
Sounds like you may have a frozen water pump or alt which could cause the belt to just slip on the pulleys.
A very hot engine will make a knocking sound..........
Just a guess.
Old Jul 14, 2006 | 11:41 AM
...Roger...'s Avatar
...Roger...
Cat. converter--they get hot and can burn things around them?
Old Jul 14, 2006 | 12:19 PM
Rich's'78's Avatar
Rich's'78
check for exhaust restriction with vacuum gauge - as it revs the manifold vac will decrease if exhaust is plugged.
Old Jul 14, 2006 | 12:34 PM
davidm_comp's Avatar
davidm_comp
Could the klanky noise and jerking car be the carb backfiring, and could the smell be the backfire burning your airfilter? Check your timing, carb adjustments/tuning, and ignition wiring.
Old Jul 14, 2006 | 12:45 PM
1Z87L8's Avatar
1Z87L8
sounds like the classic clogged exhaust syndrome to me also
To more problems
